cor
Compute Pearson product-moment (ordinary) correlations for the specified series or groups.
cor(options) arg1 [arg2 arg3...]
where arg1, arg2, etc. are the names of series or groups.
Note that this command is a limited feature version of the group view Group::cor.
wgt=name (optional)
Name of series containing weights.
wgtmethod=arg (default = “sstdev”)
Weighting method (when weights are specified using “weight=”): frequency (“freq”), inverse of variances (“var”), inverse of standard deviation (“stdev”), scaled inverse of variances (“svar”), scaled inverse of standard deviations (“sstdev”).
pairwise
Compute using pairwise deletion of observations with missing cases (pairwise samples).
out=name
Basename for saving output. All results will be saved in Sym matrices named using the string “CORR”, appended to the basename (e.g., the correlation specified by “out=my” is saved in the Sym matrix “MYCORR”).
prompt
p
Print the result.
cor height weight age
displays a Pearson correlation matrix for the three series HEIGHT, WEIGHT, and AGE.
See Group::cor for more general routines for computing correlations.
See also cov. For simple functions to perform the calculations, see @cor, and @cov.
