midas
Estimates an equation using Mixed Data Sampling (MIDAS) regression.
MIDAS regression is an estimation technique which allows for data sampled at different frequencies to be used in the same regression.
eq_name.midas(options) y x1 [x2 x3 ...] @ z1page\z1 [z2page\z2 ...]
where y, x1, etc., are the dependent and explanatory variables in the current page frequency, and z1page\z1 and z2page\z2 are the high frequency variable page\series specification.
You may not include ARMA terms in a MIDAS regression.
General options
midwgt=arg
MIDAS weight method: step function(“step”), normalized exponential Almon (“expalmon”), normalized beta function (“beta”), U-MIDAS (“umidas”), Auto-search/GETS (“autogets”) or the default Almon/PDL weighting
(“almon”).
lag=arg
Method for specifying the number of lags of the high frequency regressor to use: lag selection (“auto”), fixed (“fixed”). The default is “lag=fixed”.
maxlag=arg
Maximum number of lags of the high frequency regressor to use when using lag selection. For use when “lag=auto”. The default value is 4.
fixedlag=arg
Fixed number of lags of the high frequency regressor to use. For use when “lags=fixed”. The default value is 4.
steps=integer
Stepsize (number of high frequency periods to group). For use when “midwgt=step”.
polynomial=integer
Polynomial degree. For use when Almon/PDL weighting is employed.
beta=arg
Beta function restriction: none (“none”), trend coefficient equals 1 (“trend”), endpoints coefficient equals 0 (“endpoint”), both trend and endpoints restriction (“both”).
For use when “midwgt=beta”. The default is “beta=none”.
optmethod = arg
Optimization method for nonlinear estimation: “bfgs” (BFGS); “newton” (Newton-Raphson), “opg” or “bhhh” (OPG or BHHH), “hybrid” (initial BHHH followed by BFGS).
Hybrid is the default method.
optstep = arg
Step method for nonlinear estimation: “marquardt” (Marquardt); “dogleg” (Dogleg); “linesearch” (Line search).
Marquardt is the default method.
cov=arg
Covariance method for nonlinear models: “ordinary” (default method based on inverse of the estimated information matrix), “huber” or “white” (Huber-White sandwich).
covinfo = arg
Information matrix method for nonlinear models: “opg” (OPG); “hessian” (observed Hessian).
freq = key
Set the frequency conversion method. Key can be “first” (the higher frequency data are used from the first observation in the lower frequency period), “last” (default, the higher frequency data are used from the last observation in the lower frequency), or “match” (a specific date matching series from each page is used).
freqsrc = arg
Set the source date matching series. Only applies if freq=match is used.
freqdest = arg
Set the destination date matching series. Only applies if freq=match is used.
nodf
Do not perform degree of freedom corrections in computing coefficient covariance matrix. The default is to use degree of freedom corrections.
m=integer
Set maximum number of iterations.
c=scalar
Set convergence criterion. The criterion is based upon the maximum of the percentage changes in the scaled coefficients. The criterion will be set to the nearest value between 1e-24 and 0.2.
s
Use the current coefficient values in estimator coefficient vector as starting values in nonlinear estimation (see also param).
s=number
Determine starting values for nonlinear estimation.. Specify a number between zero and one representing the fraction of preliminary EViews chosen values. Note that out of range values are set to “s=1”. Specifying “s=0” initializes coefficients to zero. By default EViews uses “s=1”.
showopts / ‑showopts
[Do / do not] display the starting coefficient values and estimation options in the estimation output.
coef=arg
Specify the name of the coefficient vector (if specified by list); the default behavior is to use the “C” coefficient vector.
prompt
p
Print estimation results.
Auto-search/GETS options
pval=number (default = 0.05)
Set the terminal condition p-value used to determine the stopping point of each search path
nolm
Do not perform AR LM diagnostic test.
arpval=number (default = 0.025)
Set p-value used in AR LM diagnostic test.
arlags=int (default = 1)
Set number of lags used in AR LM diagnostic test.
noarch
Do not perform ARCH LM diagnostic test.
archpval=number (default = 0.025)
Set p-value used in ARCH LM diagnostic test.
archlags=int (default = 1)
Set number of lags used in ARCH LM diagnostic test.
nojb
Do not perform Jarque-Bera normality diagnostic test.
jbpval=number (default = 0.025)
Set p-value used in Jarque-Bera normality diagnostic test.
nopet
Do not perform Parsimonious Encompassing diagnostic test.
petpval=number (default = 0.025)
Set p-value used in Parsimonious Encompassing diagnostic test.
nogum
Do not include the general model as a candidate for model selection.
noempty
Do not include the empty model as a candidate for model selection.
ic =arg
Set the information criterion used in model selection: “AIC” (Akaike information criteria, default), “BIC” (Schwarz information criteria), “HQ” (Hannan-Quin criteria).
blocks=int
Override the EViews’ determination of the number of blocks in which to split the estimation sample.
equation eq1.midas(fixedlag=9, midwgt=beta, beta=endpoint) realgdp c realgdp(-1) @ monthlypage\emp(-5)
estimates a MIDAS beta weight specification using the low frequency dependent variable REALGDP and regressors C and REALGDP(-1), and 9 beta weighted lags of EMP(-5) from the “monthlypage” workfile page. The beta weight function places zero restrictions on the endpoint coefficient.
equation eq2.midas(maxlag=12, lag=auto) realgdp c realgdp(-1) @ monthlypage\emp(-5)
estimates the same equation using PDL/Almon weights. The number of lags is chosen automatically with a maximum of 12 lags.
“Midas Regression” discusses the specification and estimation of MIDAS regression models in EViews.
