ubreak
Andrews-Quandt test for unknown breakpoint.
Carries out the Andrews-Quandt test for parameter stability at some unknown breakpoint.
eq_name.ubreak(options) trimlevel @ x1 x2 x3
You must provide the level of trimming of the data. The level must be one of the following: 49, 48, 47, 45, 40, 35, 30, 25, 20, 15, 10, or 5. If the equation is specified by list and contains no nonlinear terms, you may specify a subset of the regressors to be tested for a breakpoint after an “@” sign.
wfname = series_name
Store the individual Wald F-statistics into the series series_name.
lfname = series_name
Store the individual likelihood ratio F-statistics into the series series_name.
prompt
p
Print the result of the test.
equation ppp.ls log(spot) c log(p_us) log(p_uk)
ppp.ubreak 15
regresses the log of SPOT on a constant, the log of P_US, and the log of P_UK, and then carries out the Andrews-Quandt test, trimming 15% of the data from each end.
To test whether only the constant term and the coefficient on the log of P_US are subject to a structural break, use:
ppp.ubreak @ c log(p_us)
See “Quandt-Andrews Breakpoint Test” for further discussion.
See also Equation::chow and Equation::rls.
