Object Reference : Object View and Procedure Reference : Factor
resids
Display residual covariance estimates for the factor analysis object.
factor_name.resids(options)
By default, the residuals are computed by subtracting the estimate of the common variance and the final uniqueness estimates from the observed covariance matrix. You may use the “common” option to only subtract the common variance.
common
Display the residuals computed using only the common fitted covariance.
p
Print the matrix.
factor f1.pfact x1 x2 x3 x4 x5 x6 x7 x8
f1.resids
estimates and displays the residuals for a factor analysis model applied to the series X1 to X8.
f1.resids(common)
displays the residuals computed without subtracting the uniqueness estimates.
See “Factor Analysis” for a general discussion of factor analysis. The various estimation methods are described in “Estimation Methods”.
See also fit.
