Object Reference : Object View and Procedure Reference : Geomap
Geomap
addtext
addtitle
attr
autocrop
clearhist
clearremarks
copy
display
displayname
formatshapelabel
geomap
hide
label
legend
link
load
makeattrser
map
mask
movetitle
olepush
options
save
setattr
setfillcolor
Custom Base Color
Custom Threshold
Custom Range
options
setfont
setjust
setshapelabel
show
unmask
Geomap object. Specialized object to display shapefile map data.
Geomap Declaration
geomap declare Geomap object.
Geomap Views
attr table of shapefile area attributes.
label label view.
map displays the map view of a geomap object.
display display default geomap view.
Geomap Procs
addtext place text in geomap.
addtitle place an individual title in geomap.
autocrop calculates and resets the minimum viewable size of a geomap.
clearremarks clear the contents of the remarks attribute.
copy creates a copy of the geomap.
displayname set display name.
formatshapelabel adjusts the appearance and location of one or more shape labels.
hide hides the specified area(s) in the geomap.
legend set legend specific options.
link link an attribute in the geomap to a series in the workfile.
load load a shapefile from disk.
makeattrser make alpha series containing linked attribute values.
mask make invisible specified areas in the geomap.
movetitle moves the title in the geomap to the specified location.
olepush push updates to OLE linked objects in open applications.
options change display options settings for the geomap.
save save default view to a graphics file.
setattr set the vaue of an object attribute.
setfillcolor define the fill (background) color used in geomap shapes using values in a series.
setfont set the font for the geomap text.
setjust set the horizontal justification for multi-line area labels.
setshapelabel set which attribute to use or create a custom label to use when labeling shapes.
show shows the specified area(s) in the geomap.
unmask make visible specified areas in the geomap.
Geomap Data Members
Scalar Values
@minx minimum horizontal position of the geomap.
@maxx maximum horizontal position of the geomap.
@miny minimum vertical position of the geomap.
@maxy maximum vertical position of the geomap.
@count number of areas in the geomap.
@id("attr","val") the id number of the area which has the matching attribute value for the specified attribute name.
String values
@attr("arg") string containing the value of the arg attribute, where the argument is specified as a quoted string.
@description string containing the geomap object’s description (if available).
@detailedtype string with the object type: “GEOMAP”.
@displayname string containing the geomap object’s display name. If the geomap has no display name set, the name is returned.
@ids("attr", "val") space delimited string containing the ID numbers of all the areas which has the matching attribute value for the specified attribute name.
@name string containing the geomap object’s name.
@remarks string containing the geomap object’s remarks (if available).
@type string with the object type: “GEOMAP”.
@updatetime string representation of the time and date at which the geomap was last updated.
