Object Reference : Object View and Procedure Reference : Group
freq
Compute frequency tables.
When used with a group containing a single series, freq performs a one-way frequency tabulation. The options allow you to control binning (grouping) of observations.
When used with a group containing multiple series, freq produces an N-way frequency tabulation for all of the series in the group.
group_name.freq(options)
Options common to both one-way and N-way frequency tables
dropna (default) / keepna
[Drop/Keep] NA as a category.
v=integer (default=100)
Make bins if the number of distinct values or categories exceeds the specified number.
nov
Do not make bins on the basis of number of distinct values; ignored if you set “v=integer.”
a=number (default=2)
Make bins if average count per distinct value is less than the specified number.
noa
Do not make bins on the basis of average count; ignored if you set “a=number.”
b=integer (default=5)
Maximum number of categories to bin into.
n, obs, count (default)
Display frequency counts.
nocount
Do not display frequency counts.
nolimt
Remove protections on total number of cells.
prompt
p
Print the table.
Options for one-way tables
total (default) / nototal
[Display / Do not display] totals.
pct (default) / nopct
[Display / Do not display] percent frequencies.
cum (default) / nocum
(Display/Do not) display cumulative frequency counts/percentages.
Options for N-way tables
table (default)
Display in table mode.
list
Display in list mode.
rowm (default) / norowm
[Display / Do not display] row marginals.
colm (default) / nocolm
[Display / Do not display] column marginals.
tabm (default) / notabm
[Display / Do not display] table marginals—only for more than two series.
subm (default) / nosubm
[Display / Do not display] sub marginals—only for “l” option with more than two series.
full (default) / sparse
(Full/Sparse) tabulation in list display.
totpct / nototpct (default)
[Display / Do not display] percentages of total observations.
tabpct / notabpct (default)
[Display / Do not display] percentages of table observations—only for more than two series.
rowpct / norowpct (default)
[Display / Do not display] percentages of row total.
colpct / nocolpct (default)
[Display / Do not display] percentages of column total.
exp / noexp (default)
[Display / Do not display] expected counts under full independence.
tabexp / notabexp (default)
[Display / Do not display] expected counts under table independence—only for more than two series.
test (default) / notest
[Display / Do not display] tests of independence.
group g1 hrs
g1.freq(nov,noa)
tabulates each value (no binning) of HRS in ascending order with counts, percentages, and cumulatives.
group g2 inc
g2.freq(v=20,b=10,noa)
tabulates INC excluding NAs. The observations will be binned if INC has more than 20 distinct values; EViews will create at most 10 equal width bins. The number of bins may be smaller than specified.
group labor lwage gender race
labor.freq(v=10,norowm,nocolm)
displays tables of LWAGE against GENDER for each bin/value of RACE.
See “One-Way Tabulation” and “N-Way Tabulation” for a discussion of frequency tables.
