Object Reference : Object View and Procedure Reference : Var
testlags
Perform lag exclusion (Wald) tests on a VAR.
var_name.testlags(options)
name=arg
Save the Wald test statistics in named matrix object. See below for a description of the statistics contained in the stored matrix.
p
Print the result of the test.
The “name=” option stores results in an matrix, where is the number of lagged terms and is the number of endogenous variables in the VAR. In the first columns, the i-th row, j-th column entry is the Wald statistic for the joint significance of all i-th lagged endogenous variables in the j-th equation. These Wald statistics have a distribution with degrees of freedom under the exclusion null.
In the last column, the i-th row contains the system Wald statistic for testing the joint significance of all i-th lagged endogenous variables in the VAR system. The system Wald statistics has a chi-square distribution with degrees of freedom under the exclusion null.
var var1.ls 1 6 lgdp lm1 lcpi
freeze(tab1) var1.testlags(name=lags)
The first line declares and estimates a VAR. The second line stores the lag exclusion test results in a table named TAB1, and stores the Wald statistics in a matrix named LAGS.
See “Diagnostic Views” for a discussion other VAR diagnostics.
See also Var::laglen and Var::testexog.
