Save current workfile to disk.
This usage is provided only for backward compatibility, as it has been replaced with the equivalent
wfsave command.
save [path\]file_name
Follow the keyword with a name for the file. If an explicit path is not specified, the file will be stored in the default directory, as set in the global options.
save MyWorkfile
saves the current workfile with the name MYWORKFILE.WF1 in the default directory.
save c:\data\MyWF1
saves the current workfile with the name MYWF1.WF1 in the specified directory.
