threshold
Estimation by discrete or smooth threshold least squares, including threshold autoregression.
threshold(options) y z1 [z2 z3 ...] [@nv x1 x2 x3 ...] @thresh t1 [t2 t3 ...]
List the dependent variable first, followed by a list of the independent variables that have coefficients that are allowed to vary across thresholds, followed optionally by the keyword @nv and a list of non-varying coefficient variables.
List a threshold variable or variables (for model selection) or a single integer or range pairs after the keyword @thresh. The integer or range pairs indicate a self-exciting model with the lagged dependent variable as the threshold variable.
For smooth threshold equations you may specify variables that are to be included only in the base specification or only in the alternative specification. Base-only variables should be specified in parentheses using the @base key, as in “@base(x1) @base(x2) @base(x3 x4)”. Alternative-only variables may be specified analogously using the @alt key.
Specification Options
type=arg (default=“discrete”)
Type of threshold estimation: “discrete” (discrete), “smooth” (smooth).
Discrete Threshold Options
method=arg (default=“seqplus1”)
Threshold selection method: “seqplus1” (sequential tests of single versus thresholds), “seqall” (sequential test of all possible versus thresholds), “glob” (tests of global vs. no thresholds), “globplus1” (tests of versus globally determined thresholds), “globinfo” (information criteria evaluation)., “fixedseq” (fixed number of sequentially determined thresholds), “fixedglob” (fixed number of globally determined thresholds), “user” (user-specified thresholds)
nthresh=arg (default=1)
Number of thresholds for fixed number threshold selection methods.
select=arg
Sub-method setting (options depend on “method=”).
(1) if “method=glob”: Sequential ("seq") (default), Highest significant ("high"), ("udmax"), ("wdmax").
(2) if “method=globinfo”: Schwarz criterion (“bic” or “sic”) (default), Liu-Wu-Zidek criterion (“lwz”).
trim=arg (default=5)
Trimming percentage for determining minimum segment size (5, 10, 15, 20, 25).
maxthresh=integer (default=5)
Maximum number of thresholds to allow (not applicable if “method=seqall”).
maxlevels=integer (default=5)
Maximum number of threshold levels to consider in sequential testing (applicable when “method=sequall”).
size=arg (default=5)
Test sizes for use in sequential determination and final test evaluation (10, 5, 2.5, 1) corresponding to 0.10, 0.05, 0.025, 0.01, respectively
heterr
Assume regimes specific error distributions in variance computation.
commondata
Assume a common distribution for the data across segments (only applicable if original equation is estimated with a robust covariance method, “heterr” is not specified).
Smooth Threshold Options
smoothtrans=arg (default=“logistic”)
Smooth threshold transition function: “logistic” (logistic), “logistic2” (second-order logistic), “exponential” (exponential), “normal” (normal).
smoothstart=arg (default=“grid_conc”)
Smoth threshold starting value method: or fixed number threshold selection methods: “grid_conc” (grid search with concentrated regression coefficients”, “grid_zeros” (grid search with zero regression coefficients), “data” (data-based), “user” (user-specified using the contents of the coefficient vector in the workfile).
smoothst=arg
General Options
w=arg
Weight series or expression.
wtype=arg (default=“istdev”)
Weight specification type: inverse standard deviation (“istdev”), inverse variance (“ivar”), standard deviation (“stdev”), variance (“var”).
wscale=arg
Weight scaling: EViews default (“eviews”), average (“avg”), none (“none”).
The default setting depends upon the weight type: “eviews” if “wtype=istdev”, “avg” for all others.
cov=keyword
Covariance type (optional): “white” (White diagonal matrix), “hac” (Newey-West HAC).
nodf
Do not perform degree of freedom corrections in computing coefficient covariance matrix. The default is to use degree of freedom corrections.
covlag=arg (default=1)
Whitening lag specification: integer (user-specified lag value), “a” (automatic selection).
covinfosel=arg (default=“aic”)
Information criterion for automatic selection: “aic” (Akaike), “sic” (Schwarz), “hqc” (Hannan-Quinn) (if “lag=a”).
covmaxlag=integer
Maximum lag-length for automatic selection (optional) (if “lag=a”). The default is an observation-based maximum of .
covkern=arg (default=“bart”)
Kernel shape: “none” (no kernel), “bart” (Bartlett, default), “bohman” (Bohman), “daniell” (Daniel), “parzen” (Parzen), “parzriesz” (Parzen-Riesz), “parzgeo” (Parzen-Geometric), “parzcauchy” (Parzen-Cauchy), “quadspec” (Quadratic Spectral), “trunc” (Truncated), “thamm” (Tukey-Hamming), “thann” (Tukey-Hanning), “tparz” (Tukey-Parzen).
covbw=arg (default=“fixednw”)
Kernel Bandwidth: “fixednw” (Newey-West fixed), “andrews” (Andrews automatic), “neweywest” (Newey-West automatic), number (User-specified bandwidth).
covnwlag=integer
Newey-West lag-selection parameter for use in nonparametric kernel bandwidth selection (if “covbw=neweywest”).
covbwint
Use integer portion of bandwidth.
prompt
p
Print basic estimation results.
threshold(method=fixedseq, type=discrete) ss_transf c ss_transf(-1 to -11) @thresh 2
uses the fixed number of thresholds test to determine the optimal threshold in a model regressing SS_TRANSF on the threshold variables C and SS_TRANSF(-1 to -11).
threshold(method=fixedseq, type=discrete) ss_transf c ss_transf(-1 to -11) @thresh 1 5
uses the fixed number of thresholds test to determine the optimal threshold and does model selection over lags of SS_TRANSF from SS_TRANSF(-1) to SS_TRANSF(-5).
threshold(method=user, threshold=7.44) ss_transf c @nv ss_transf(-1 to -11) @thresh 2
estimates the model with one user-specified threshold value. In addition, the variables SS_TRANSF(-1 to -11) are restricted to have common coefficients across the regimes.
See “Discrete Threshold Regression” for a discussion of the various forms of threshold models.
