Close the active or specified workfile.
wfclose(options) [name]
wfclose allows you to close the currently active workfile. You may optionally provide the name of a workfile if you do not wish to close the active workfile. If more than one workfile is found with the same name, the one most recently opened will be closed.
noerr | Do not error if a name is provided and no workfile with that name is found. |
wfclose
closes the workfile that was most recently active.
wfclose basics
closes the workfile named BASICS.
