Command Reference : Function Reference : Function Reference: S
@skew
Skewness.
Computes the skewness of the elements of x.
Syntax: @skew(x[, s])
x: series, vector, matrix
s: (optional) sample string or object when x is a series and assigning to a series
Return: number
The skewness is calculated as
where is the sample mean, and is an estimator for the standard deviation that is based on the biased estimator for the variance
The skewness of a symmetric distribution, such as the normal distribution, is zero. Positive skewness means that the distribution has a long right tail and negative skewness implies that the distribution has a long left tail.
If x = @nrnd, then
= @skew(x)
returns a value close to 0 in large samples (since the normal distribution is symmetric).
See also @mean, @var, and @kurt.
