Command Reference : Function Reference : Function Reference: S
@svdfull
Singular value decomposition (full) of matrix
Syntax: @svdfull(m1, m2, m3)
m1: matrix, sym
m2: matrix
m3: matrix, sym
Return: matrix
Performs a singular value decomposition of the matrix m1.
The matrix is returned by the function, the matrix m2 will be assigned (resized if necessary) the matrix , and the matrix m3 will be assigned (resized if necessary) the other matrix, , of the decomposition. The singular value decomposition satisfies:
where is a diagonal matrix with the singular values along the diagonal. Singular values close to zero indicate that the matrix may not be of full rank. See the @rank function for a related discussion.
matrix x = @mnrnd(5, 7)
matrix w
matrix v
matrix u = @svdfull(x, w, v)
performs the full SVD of the matrix X. U is , W is diagonal matrix with singular values on the diagonal, and V is .
Alternately, if the rank is less than the number of rows,
matrix x = @mnrnd(7, 5)
then U is , W is a matrix with the singular values on the main diagonal and V is a matrix.
In both cases, the following demonstrate the properties of the decomposition:
sym i1 = @inner(u)
sym i2 = @inner(v)
matrix x1 = u * w * v.@t
where I1 and I2 and the identity matrix, and X1 is equal to X.
See also @svd, @cholesky, @lu, and @qr.
