Test for autoregressive conditional heteroskedasticity (ARCH).
Carries out Lagrange Multiplier (LM) tests for ARCH in the residuals.
Note that a more general version of the ARCH test is available using
Equation::archtest.
archtest(options)
You must specify the order of ARCH for which you wish to test. The number of lags to be included in the test equation should be provided in parentheses after the arch keyword.
Other Options:
p | Print output from the test. |
ls output c labor capital
archtest(4)
Regresses OUTPUT on a constant, LABOR, and CAPITAL, and tests for ARCH up to order 4.
equation eq1.arch sp500 c
archtest(4)
Estimates a GARCH(1,1) model with mean equation of SP500 on a constant and tests for additional ARCH up to order 4. Note that when performing an archtest after an arch estimation, EViews uses the standardized residuals (the residual of the mean equation divided by the estimated conditional standard deviation) to form the test.
See
“ARCH LM Test” for further discussion of testing ARCH and
“ARCH and GARCH Estimation” for a discussion of working with ARCH models in EViews.
See
Equation::archtest for the equivalent object command. See
Equation::hettest for a more general version of the ARCH test.
