fitoutliers |
sens=arg | Set the sensitivity level. Valid arguments are “low”, “medium” (default), and “high”. |
nofence | Do not perform Tukey and mean/standard deviation fences. |
nowave | Do not perform Wavelet Outlier detection. |
noarma | Do not perform ARMA based outlier detection. ARMA outlier detection is only available for least squares equations containing ARMA terms, and is turned on by default. |
noinf | Do not perform influence statistic (not including DFBETAS) based outlier detection. Influence statistic outlier detection is only available for linear least squares equations, and is turned on by default. |
dfbeta | Perform DFBETA influence statistic based outlier detection. DFBETA based outlier detection is only available for linear least squares equations, and is turned off by default. |
tukeyk=arg | Set the value k in the Tukey fence detection routine. This will override the value of k set by the sens= option. |
meanstdevk=arg | Set the value k in the mean/standard deviation fence detection routine. This will override the value of k set by the sens= option. |
wavesig=arg | Set the value false discovery rate significance value used in the Wavelet Outlier detection routine. This will override the value set by the sens= option. |
armac=arg | Set the value c in the ARMA outlier detection routine. This will override the value of c set by the sens= option. |
rsbound=arg | Set the value c in RSTUDENT outlier detection. This will override the value of c set by the sens= option. |
hbound=arg | Set the value c in HatMatrix outlier detection. This will override the value of c set by the sens= option. |
dfsbound=arg | Set the value c in DFFITS outlier detection. This will override the value of c set by the sens= option. |
covbound=arg | Set the value c in CovRatio outlier detection. This will override the value of c set by the sens= option. |
betabound=arg | Set the value c in DFBETA outlier detection. This will override the value of c set by the sens= option. |
series=name | Create a new series in the workfile, named name, containing a value of 1 for any observations identified as an outlier, and a value of 0 for any observation identified as not an outlier. |
datestring=name | Create a new string object in the workfile containing the dates (or observation identifiers) for any observations identified as an outlier. |
grlabels | Turn on observation labels on the outlier graph. |
p | Print results. |
