ordered |
d=arg (default=“n”) | Specify likelihood: normal likelihood function, ordered probit (“n”), logistic likelihood function, ordered logit (“l”), Type I extreme value likelihood function, ordered Gompit (“x”). |
optmethod = arg | Optimization method: “bfgs” (BFGS); “newton” (Newton-Raphson), “opg” or “bhhh” (OPG or BHHH), “legacy” (EViews legacy). Newton-Raphson is the default method. |
optstep = arg | Step method: “marquardt” (Marquardt); “dogleg” (Dogleg); “linesearch” (Line search). Marquardt is the default method. |
cov=arg | Covariance method: “ordinary” (default method based on inverse of the estimated information matrix), “huber” or “white” (Huber-White sandwich method)., “glm” (GLM method), “cr” (cluster robust). |
covinfo = arg | Information matrix method: “opg” (OPG); “hessian” (observed Hessian). (Applicable when non-legacy “optmethod=”.) |
df | Degree-of-freedom correct the coefficient covariance estimate.(For non-cluster robust methods estimated using non-legacy estimation). |
h | Huber-White quasi-maximum likelihood (QML) standard errors and covariances. (Legacy option Applicable when “optmethod=legacy”). |
crtype=arg (default “cr1”) | Cluster robust weighting method: “cr0” (no finite sample correction), “cr1” (finite sample correction), when “cov=cr”. |
crname=arg | Cluster robust series name, when “cov=cr”. |
m=integer | Set maximum number of iterations. |
c=scalar | Set convergence criterion. The criterion is based upon the maximum of the percentage changes in the scaled coefficients. The criterion will be set to the nearest value between 1e-24 and 0.2. |
s | Use the current coefficient values in “C” as starting values (see also
param). |
s=number | Specify a number between zero and one to determine starting values as a fraction of preliminary EViews default values (out of range values are set to “s=1”). |
showopts / ‑showopts | [Do / do not] display the starting coefficient values and estimation options in the estimation output. |
coef=arg | Specify the name of the coefficient vector (if specified by list); the default behavior is to use the “C” coefficient vector. |
p | Print results. |
