Object Reference : Object View and Procedure Reference : Factor
ipf
Iterated principal factors estimation of the factor model.
factor_name.ipf(options) x1 [x2 x3...] [@partial z1 z2 z3...]
factor_name.ipf(options) matrix_name [[obs] [conditioning]] [@ name1 name2 name3...]
The first method computes the observed dispersion matrix from a set of series or group objects. Simply append a period and the ipf keyword to the name of your object, followed by the names of your series and groups, You may optionally use the keyword @partial and append a list of conditioning series.
In the second method you will provide the name of the observed dispersion matrix, and optionally, the number of observations and the rank of the set of conditioning variables. If the latter is not provided, it will be set to 1 (representing the constant in the standard centered variance calculations). You may also provide names for the columns of the correlation matrix by entering the @-sign followed by a list of valid series names.
Estimation Options
heywood=arg (default=“stop”)
Method for handling Heywood cases (negative uniqueness estimates): “stop” (stop and report final results), “last” (stop and report previous iteration results”, “reset” (set negative uniquenesses to zero and continue), “ignore” (ignore and continue).
maxit=integer
Maximum number of iterations.
conv=scalar
Set convergence criterion. The criterion is based upon the maximum of the percentage changes in the scaled estimates. The criterion will be set to the nearest value between 1e-24 and 0.2.
showopts / ‑showopts
[Do / do not] display the starting coefficient values and estimation options in the rotation output.
prompt
p
Print basic estimation results.
Number of Factors Options
n=arg or fsmethod=arg (default=“map”)
Number of factors: “kaiser” (Kaiser-Guttman greater than mean), “mineigen” (Minimum eigenvalue criterion; specified using “eiglimit”), “varfrac” (fraction of variance accounted for; specified using “varlimit”), “map” (Velicer’s Minimum Average Partial method), “bstick” (comparison with broken stick distribution), “parallel” (parallel analysis: number of replications specified using “pnreps”; “pquant” indicates the quantile method value if employed), “scree” (standard error scree method), “bn” (Bai and Ng (2002)), “ah” (Ahn and Horenstein (2013)), integer (user-specified integer value).
eiglimit=number (default=1)
Limit value for retaining factors using the eigenvalue comparison (where “n=mineigen”).
varlimit=number (default=0.5)
Fraction of total variance explained limit for retaining factors using the variance limit criterion (where “n=varlimit”).
porig
Use the unreduced matrix for parallel analysis (the default is to use the reduced matrix).
For parallel analysis only (“n=parallel”).
preps= integer (default=100)
Number of parallel analysis repetitions.
pquant=number
Quantile value for parallel analysis comparison (if not specified, the mean value will be employed).
pseed=positive integer
Seed the random number generator for parallel analysis.
If not specified, EViews will seed the random number generator with a single integer draw from the default global random number generator.
prnd=arg (default=“kn” or method previously set using rndseed)
Type of random number generator for the simulation: improved Knuth generator (“kn”), improved Mersenne Twister (“mt”), Knuth’s (1997) lagged Fibonacci generator used in EViews 4 (“kn4”) L’Ecuyer’s (1999) combined multiple recursive generator (“le”), Matsumoto and Nishimura’s (1998) Mersenne Twister used in EViews 4 (“mt4”).
mfmethod=arg (default=“user”)
Maximum number of components used by selection methods: “schwert” (Schwert’s rule, default), “ah” (Ahn and Horenstein’s (2013) suggestion), “rootsize” (), “size” (), “user” (user specified value), where is the number of series and is the number of observations.
(1) For use with all components retention methods apart from user-specified (“fsmethod=user”).
(2) If setting “mfmethod=user”, you may specify the maximum number of components using “rmax=”.
(3) Schwert’s rule sets the maximum number of components using the rule: let
for and let ; then the default maximum lag is given by
rmax=arg (default=all)
User-specified maximum number of factors to retain (for use when “mfmethod=user”).
fsic=arg (default=avg)
Factor selection criterion (when “fsmethod=bn”): “icp1” (ICP1), “icp2” (ICP2), “icp3” (ICP3), “pcp1” (PCP1), “pcp2” (PCP1), “pcp3” (ICP3), “avg” (average of all criteria ICP1 through PCP3).
Factor selection criterion (when “fsmethod=ah”): “er” (eigenvalue ratio), “gr” (growth ratio), “avg” (average of eigenvalue ratio and growth ratio).
Factor selection criterion (when “fsmethod=simple”): “min” (minimum of: minimum eigenvalue, cumulative eigenvalue proportion, and maximum number of factors), “max” (maximum of: minimum eigenvalue, cumulative eigenvalue proportion, and maximum number of factors), “avg” (average the optimal number of factors as specified by the min and max rule, then round to the nearest integer).
demeantime
Demeans observations across time prior to component selection procedures, when “n=bn” or “n=ah”.
sdizetime
Standardizes observations across time prior to component selection procedures, when “n=bn” or “n=ah”.
demeancross
Demeans observations across cross-sections prior to component selection procedures, when “n=bn” or “n=ah”.
sdizecross
Standardizes observations across cross-sections prior to component selection procedures, when “n=bn” or “n=ah”.
Initial Communalities Options
priors=arg
Method for obtaining initial communalities: “smc” (squared multiple correlations), “max” (maximum absolute correlation”), “pace” (noniterative partitioned covariance estimation), “frac” (fraction of the diagonals of the original matrix; specified using “priorfrac=”), “random” (random fractions of the original diagonals), “user” (user-specified vector; specified using “priorunique”).
priorfrac=number
User-specified common fraction (between 0 and 1) to be used when “priors=frac”.
priorunique=arg
Vector of initial uniqueness estimates to be used when “priors=user”. By default, the values will be taken from the corresponding elements of the coefficient vector C.
Covariance Options
cov=arg (default=“cov”)
Covariance calculation method: ordinary (Pearson product moment) covariance (“cov”), ordinary correlation (“corr”), Spearman rank covariance (“rcov”), Spearman rank correlation (“rcorr”), Kendall’s tau-b (“taub”), Kendall’s tau-a (“taua”), uncentered ordinary covariance (“ucov”), uncentered ordinary correlation (“ucorr”).
User-specified covariances are indicated by specifying a sym matrix object in place of a list of series or groups in the command.
wgt=name (optional)
Name of series containing weights.
wgtmethod=arg (default = “sstdev”)
Weighting method (when weights are specified using “weight=”): frequency (“freq”), inverse of variances (“var”), inverse of standard deviation (“stdev”), scaled inverse of variances (“svar”), scaled inverse of standard deviations (“sstdev”).
Only applicable for ordinary (Pearson) calculations. Weights specified by “wgt=” are frequency weights for rank correlation and Kendall’s tau calculations.
pairwise
Compute using pairwise deletion of observations with missing cases (pairwise samples).
df
Compute covariances with a degree-of-freedom correction for the mean (for centered specifications), and any partial conditioning variables.
factor f1.ipf(n=2, maxit=4) var1 var2 var3 var4
declares the factor object F1 then extracts two factors from the variables VAR1–VAR4 by the iterative principal factor method, with a maximum of four iterations.
f1.ipf(conv=1e-9, heywood=reset) group01
sets the convergence criterion to 1e-9, and estimates the factor model for the series in GROUP01. If encountered, negative uniqueness estimates will be set to zero and the estimation will proceed.
f1.ipf(conv=1e-9, heywood=reset) group01 @partial ser1 ser2
estimates the same specification using the partial correlation for GROUP01, conditional on the series SER1 and SER2.
f1.ipf(n=parallel) sym01 424
estimates the iterative principal factor model using the observed matrix SYM01. The number of observations is 424, and the number of factors is determined using parallel analysis.
See “Factor Analysis” for a general discussion of factor analysis. The various estimation methods are described in “Estimation Methods”.
See also Factor::gls, Factor::ml, Factor::pace, Factor::pf, Factor::uls.
