Command Reference : Function Reference : Function Reference: H
@hcat
Vertically concatenate matrices.
Syntax: @hcat(m1, m2[, m3, ...])
m#: matrix, vector, svector or sym
Return: matrix
Performs vertical concatenation of two matrix objects. Each of the m# must have the same number of columns.
The result will have the same number of rows and sum of the number of columns of the m#.
For example, if m1 is a matrix with m rows and k columns, and m2 is a matrix with m rows and p columns, then @hcat will return a matrix with m rows and (k+p) columns.
vector v1 = @fill(1, 2, 3)
matrix k1 = @hcat(v1, 2*v1, 3*v1)
produces the matrix K1 which horizontally join the vectors V1, 2*V1 and 3*V1.
matrix g1 = @mnrnd(3, 3)
sym s1 = @identity(3)
matrix m1 = @hcat(g1, s1, v1)
horizontally joins the random normal matrix G1, the identity matrix, and the vector V1.
See also @vcat.
