Command Reference : Function Reference : Function Reference: W
@wfattrnames
Syntax: @wfattrnames(attr[, obj, page, opt])
attr: string
obj: (optional) string
page: (optional) string
opt: (optional) integer
Return: string
Returns a string list of all attribute names that match the attr pattern in the specified page list or active page and, optionally, whose object names also match the obj name pattern.
• The attr is a space delimited list of attribute name patterns. The list may be made up of any number of names, or “?” (indicates any single character) or “*” (indicates any number of characters) patterns.
• The obj list may be made up of any number of names, or “?” (indicates any single character) or “*” (indicates any number of characters) patterns separated by spaces.
• The page list may be made up of any number of workfile page names, or “?” (indicates any single character) or “*” (indicates any number of characters) patterns separated by spaces. If a page list is not specified, only the active workfile page will be used.
• The opt is an integer value indicating how a “*” or “?” in the attr should be treated when matching. Use “0” to treat the characters as wildcards, and “1” to treat the characters as literals.
Matches are not case-sensitive.
If a workfile contains three pages named “PAGE1”, “PAGE2”, and “PAGE3”,
@wfattrnames("M*")
returns the list of attributes for the objects in the active page that begin with “M”. Alternatively,
@wfattrnames("M* S*", "*", "page1 page2")
returns the list of attributes for all the objects on PAGE1 and PAGE2 that begin with “M” and “S”.
If an object on PAGE1 had an attribute named “*Note” and another object on the same page had an attribute named “footnote” the command
@wfattrnames("*NOTE", "*", "page1")
will return “*Note footnote” since the “*” in “*Note” is treated as a wildcard. However, the command
@wfattrnames("*NOTE", "*", "page1", 1)
will return “*Note”, since the “*” in “*Note” is treated as a literal.
See also @attrnames, @attrvals, and @wfattrvals.
