Command Reference : Function Reference : Function Reference: W
@wfattrvals
Syntax: @wfattrvals(attr[, obj, page, opt])
attr: string
obj: (optional) string
page: (optional) string
opt: (optional) integer
Return: string
Returns a string list of all attribute values that match the attr pattern in the specified page list or active page and, optionally, whose object names also match the obj name pattern.
• The attr is a space delimited list of attribute value patterns. The list may be made up of any number of names, or “?” (indicates any single character) or “*” (indicates any number of characters) patterns.
• The obj list may be made up of any number of names, or “?” (indicates any single character) or “*” (indicates any number of characters) patterns separated by spaces.
• The page list may be made up of any number of workfile page names, or “?” (indicates any single character) or “*” (indicates any number of characters) patterns separated by spaces. If a page list is not specified, only the active workfile page will be used.
• The opt is an integer value indicating how a “*” or “?” in the attr should be treated when matching. Use “0” to treat the characters as wildcards, and “1” to treat the characters as literals.
Matches are not case-sensitive.
If a workfile contains three pages named “PAGE1”, “PAGE2”, and “PAGE3”, then
@wfattrvals("M*", "*", "PAGE1")
return the string list of all attribute values that begin with “M” on PAGE1. Alternatively,
@wfattrvals("M* D*", "GDP", "PAGE1 PAGE2")
returns the list of attribute values for the objects PAGE1/GDP and PAGE2/GDP that begin with “M” and “D”.
If on PAGE1 there was an object that had one attribute value of “*Mar” and second attribute value of “Mar”, the command
@wfattrvals("*mar", "*", "PAGE1")
will return “*mar mar” since the “*” in “*mar” is treated as a wildcard and the values “Mar” and “*Mar” both match the attribute list. However, the command
@wfattrvals("*mar", "*", "PAGE1", 1)
will only return “*mar”, since the “*” in “*Mar” is treated as a literal and only “*Mar” matches the list.
See also @attrnames, @attrvals, and @wfattrnames.
