Object Reference : Object View and Procedure Reference : Geomap
formatshapelabel
Adjusts the appearance and location of one or more shape labels.
geomap_name.formatshapelabel(options) [shapes]
where options is the set of the label characteristics to be changed, shapes is the list of shapes whose labels are to be modified.
geomap_name.formatshapelabel (shape_attribute, label_attributes) attr_value
where shape_attribute is the name of the shape attribute used to match attr_value.
font([face], [pt], [+/- b], [+/- i], [+/- u], [+/- s])
Set characteristics of text font. The font name (face), size (pt), and characteristics are all optional. face should be a valid font name, enclosed in double quotes. pt should be the font size in points. The remaining options specify whether to turn on/off boldface (b), italic (i), underline (u), and strikeout (s) styles.
textcolor(arg)
Sets the color of the text. arg may be one of the predefined color keywords, or it may be specified using individual red-green-blue (RGB) components using the “@RGB” or “@HEX” functions. The arguments to the @RGB function are a set of three integers from 0 to 255, representing the RGB values of the color. The arguments to the “@HEX” function are a set of six characters representing the RGB values of the color in hexadecimal. Each two character set represents a red, green or blue component in the range '00' to 'FF'. For a description of the available color keywords see “Color definitions”.
fillcolor(arg)
Sets the background fill color of the text box. arg may be one of the predefined color keywords, or it may be specified using individual red-green-blue (RGB) components using the “@RGB” or “@HEX” functions. The arguments to the @RGB function are a set of three integers from 0 to 255, representing the RGB values of the color. The arguments to the “@HEX” function are a set of six characters representing the RGB values of the color in hexadecimal. Each two character set represents a red, green or blue component in the range '00' to 'FF'. For a description of the available color keywords see “Color definitions”.
framecolor(arg)
Sets the color of the text box frame. arg may be one of the predefined color keywords, or it may be specified using individual red-green-blue (RGB) components using the “@RGB” or “@HEX” functions. The arguments to the @RGB function are a set of three integers from 0 to 255, representing the RGB values of the color. The arguments to the “@HEX” function are a set of six characters representing the RGB values of the color in hexadecimal. Each two character set represents a red, green or blue component in the range '00' to 'FF'. For a description of the available color keywords see “Color definitions”.
keep
When adding text to one of the predefined positions (left, right, top, bottom), any existing text in that position will be deleted and replaced with the new text. Use the “keep” option to preserve the existing text and place the second text object on top of the text in that position.
geomap1.formatshapelabel(x) 2 5 10
will enclose the label in a large box for the second, fifth, and tenth shape in the GEOMAP1 geomap object.
geomap1.formatshapelabel(attr=statename, textcolor(red), pos(100,100)) nevada “south dakota”
will set the text color to red and move the label to (100, 100) for the shapes in GEOMAP1 whose state attribute matches nevada and south dakota.
