User’s Guide : Basic Data Analysis : Geomaps : Creating and Configuring a Geomap
Loading a Shapefile
Linking Shapes to Observations
Labeling the Shapes
Fill Values Labeling
Custom Labeling
Assigning Fill Colors
Hiding Observations and Shapes
Additional Appearance Settings
To create a geomap object in a workfile, you may select Object/New Object/Geomap from the workfile menu, optionally enter a name in the Name for object edit field, and click on OK. Alternately, you may simply enter the declaration command geomap followed by an optional name in the command window, then press Enter.
Loading a Shapefile
To load a shapefile simply drop a shapefile (“.prj”) file in the client area of the window, or click to open a file dialog and navigate to and open the file.
(If you do not wish to use workfile data to label or color shapes, you may skip the following step. While this step is optional, geomaps are at their most useful when you associate individual shapes in the shapefile to observations in the workfile.)
Once a shapefile has been loaded, you will be prompted to link the shapes in the shapefile with the observations in the workfile:
• First, you should use the left dropdown menu to select the shapefile attribute whose values you will match to data in the workfile.
• Next, you should use the right dropdown menu to select the series in the workfile that will be used to identify which observations in the workfile will be paired to a shape.
As you make selections in the dropdown menus, EViews will show you a partial list of the unique values from the specified shapefile attribute and series. Matches between the values in the shapefile attributes and the values series will be used for linking a shape with a workfile observation.
If there is more than one observation in the series that matches a shapefile attribute value, the first observation matching observation will be used.
Below each box is a description identifying how many elements in each list will be paired. Note that there may be some shapes in the shapefile without a corresponding observation in the workfile and vice versa.
Once you are satisfied with your selections, click on OK to continue.
Labeling the Shapes
Custom Labeling
The Label dropdown menu on the geomap button bar allows you to set the shape labels using shapefile attributes, values for series in the workfile, custom labels, or no labels.
After first loading a shapefile, you will see a rendering of the shapes. Each shape will be labeled using the first attribute found in the shapefile. In the example below, STATEFP was the first attribute in the file:
The Label dropdown will contain all of the shapefile attributes, as well as entries for FillValues, Custom and None, and you may use the dropdown menu to quickly change labels between any of the entries. The None is self-explanatory, FillValues and Custom will be described below.
For example, changing the label to show the “NAME” attribute yields:
Should the default position of a label not be ideal, it may be adjusted manually. Simply click and drag a label to its desired location:
If you have successfully linked the shapes in the shapefile to the observations in the workfile ( “Linking Shapes to Observations”), you may also label the shapes using values of a series in the workfile.
Enter a series name in the FillSeries edit field on the button bar, and use the Label dropdown to select FillValues. EViews will use the values in the specified series as labels for each shape. For example, we may select the POP_FEMALE series to label easy of the shapes in our linked geomap:
Custom Labeling
To custom label each shape, you must first define the contents of each label. Click on Properties, then the Label tab, to display a dialog in which you may provide a definition for custom labels:
You may use a combination of attributed names (enclosed in “[“ and “]”), the special keyword “[FillValue]” to refer to the values in the FillSeries described in “Fill Values Labeling”.
You may use also apply custom formatting including font family and size using the Font tab.
Here we use the attribute “NAME” and the value of the workfile series POP_FEMALE to create a custom, multi-line label for each shape:
For legibility, we have manually adjusted the position of some of the labels by dragging them to new locations
Once you have successfully linked the shapes in the shapefile to the observations in the workfile ( “Linking Shapes to Observations”), you may define a colormap to assign values from the workfile to each shape, and to use these values for coloring. To set the color settings for each shape, press the Properties button and then choose the Color tab:
Here, we see that the fill Base color is set to a Single color of white. The Preview display reflects this setting.
We are going to define a custom color map that uses the female population series (POP_FEMALE) to determine the fill color (for more on colormaps, see “Value-Based Text and Fill Coloring”).
We change the settings in the dialog so that the colors will blend from blue to red as the population ranges from 0 to 570,000, regions with NA values for POP_FEMALE will be displayed with a white fill, and values outside of the range will be grey fill. We will use the a color range specification to define these settings.
Click on the Add Range button, to bring up the custom range setting dialog:
Notice that we use the default Name of Range. If we are going to create more than one range specification, you may wish to provide a more informative name.
Clicking on OK creates the custom specification “Range” and returns to the main Properties dialog. The Preview window on the bottom shows the current color settings:
After applying the colormap by pressing OK in the dialog and changing the slider to 2020, we now see the female population in year 2020:
Recall that geomap contains all of the shapes in the original shapefile. When you link the observations in your workfile to these shapes, you create a correspondence between observations in the workfile and those shapes.
Note however, that this correspondence may not be complete:
• There may be observations in the workfile that do not have shapes in the shapefile
• There may be shapes in the shapefile which do not correspond to observations in the workfile
Understanding these different classes of observations is important to understanding what EViews will show when drawing a geomap.
By default, EViews will show all of the shapes in the shapefile, whether or not they correspond to an observation in the workfile. You may restrict the display of these shapes in the following fashion:
• You may instruct EViews to filter out shapes corresponding to observations that are not in the current sample by pressing on Smpl +/- button.
(Note that when a sample filter is applied, all shapes not associated with observations will also be hidden).
To remove the filter, press the button again to toggle the settings.
• Additionally, you may instruct EViews to hide specific shapes by clicking on the Properties button and selecting the Appearance tab:
Simply check and uncheck the shape regions as desired. Note that the label for each of the shapes is taken from the label setting as described in “Labeling the Shapes”.
Lastly, note that if you have applied a workfile sample filter, a shape region must satisfy both the sample filter and the Appearance settings filters. Thus, if an observation is in the current sample, but it’s Appearance checkbox is unchecked, it will be hidden. Likewise, if a shape’s Appearance checkbox is selected, but the observation is not in the current sample, it will be hidden.
In addition to allowing you to show and hide specific shapes, the Appearance tab has settings for the shape outline color (Outline Color), and whether to show a colormap legend (Display legend).
