Object Reference : Object View and Procedure Reference : Matrix
testbtw
Test equality of the mean, median or variance of the series in the group.
group_name.testbtw(options)
By default, testbtw will test for equality of means, but you may specify instead tests of medians or variances as an option, and choose whether to use balanced or unbalanced samples.
mean (default)
Test equality of mean.
med
Test equality of median.
var
Test equality of variance.
c
Use common (balanced) sample for computing statistics after removing observations with missing values for any series in the group.
By default, EViews computes the statistics for each series using an individual (potentially unbalanced) sample after removing observations with missing values for the series.
prompt
p
Print the test results.
The commands
group g1 wage_m wage_f
g1.testbtw
uses both parametric ANOVA and nonparametric approaches to test the equality of means of the two series WAGE_M and WAGE_F using individual samples to compute the means. Alternately, the command,
g1.testbtw(var, c)
tests for equality of variances using a balanced sample after listwise deletion of rows with missing values.
See “Tests of Equality” for further discussion of these tests.
See also Series::testby and Series::teststat.
