Object Reference : Object View and Procedure Reference : Matrix
testbtw
Test equality of the mean, median or variances of the columns in a matrix.
matrix_name.testbtw(options)
By default, testbtw will test for equality of means, but you may specify instead tests of medians or variances as an option, and choose whether to use balanced or unbalanced samples.
mean (default)
Test equality of means.
med
Test equality of medians.
var
Test equality of variances.
c
Use common (balanced) sample for computing statistics after removing rows with missing values for any element in the row.
By default, EViews computes the statistics for each column using a individual (potentially unbalanced) sample after removing observations with missing values for the column.
prompt
p
Print the test results.
The command
mat1.testbtw
uses both parametric ANOVA and nonparametric approaches to test the equality of the means of the columns of MAT1 using individual samples. Alternately, the command,
mat1.testbtw(var, c)
tests for equality of the column variances using a balanced sample after listwise deletion of rows with missing values.
See “Tests of Equality” for further discussion of these tests.
See also Series::testby and Series::teststat.
