Drop equations for one or more endogenous variables in the model.
model_name.drop(options) var_list
Where var_list is a space delimited list of variables whose equations will be dropped from the model. By default if a variable is contained in a multi-equation object, such as a system, VAR or model, the entire object will be dropped, which will also drop the specification for the other variables defined in that object.
nomult | Do not drop multi-equation objects |
noerr | Suppress variable not found errors |
m1.drop gdp
will drop the equation/object which has GDP as a dependent variable from the model M1.
m2.drop(nomult) gdp unemp
will drop the equations which have GDP or UNEMP as dependent variables. Systems, VARs, models, etc… will not be dropped.
