Object Reference : Object View and Procedure Reference : Pool
coint
Panel cointegration tests.
pool_name.coint(option) pool_ser1 pool_ser2 [pool_ser3]...
Follow the pool name with the coint keyword, any options, and a list of two or more ordinary or pool series.
You may specify the type using one of the following keywords:
Pedroni (default)
Pedroni (1994 and 2004).
Kao
Kao (1999)
Fisher
Fisher - pooled Johansen
Depending on the type selected above, the following may be used to indicate deterministic trends:
const (default)
Include a constant in the test equation.
Applicable to Pedroni and Kao tests.
trend
Include a constant and a linear time trend in the test equation.
Applicable to Pedroni tests.
none
Do not include a constant or time trend.
a
No deterministic trend in the data, and no intercept or trend in the cointegrating equation.
Applicable to Fisher tests.
b
No deterministic trend in the data, and an intercept but no trend in the cointegrating equation.
c
Linear trend in the data, and an intercept but no trend in the cointegrating equation.
d
Linear trend in the data, and both an intercept and a trend in the cointegrating equation.
e
Quadratic trend in the data, and both an intercept and a trend in the cointegrating equation.
Additional options:
ac=arg (default= “bt”)
Method of estimating the frequency zero spectrum: “bt” (Bartlett kernel), “pr” (Parzen kernel), “qs” (Quadratic Spectral kernel).
band=arg (default= “nw”)
Method of selecting the bandwidth, where arg may be “nw” (Newey-West automatic variable bandwidth selection), or a number indicating a user-specified common bandwidth.
lag=arg
For Pedroni and Kao tests, the method of selecting lag length (number of first difference terms) to be included in the residual regression. For Fisher tests, a pair of numbers indicating lag.
info=arg (default= “sic”)
Information criterion to use when computing automatic lag length selection: “aic” (Akaike), “sic” (Schwarz), “hqc” (Hannan-Quinn).
maxlag=int
Maximum lag length to consider when performing automatic lag length selection, where int is an integer. The
default=
where is the length of the cross-section.
disp=arg (default=500)
Maximum number of individual results to be displayed.
prompt
p
Print results.
pool01.coint(fisher,lag=1 2,c) y? x1? x2?
performs a Johansen test for pool series Y?, X1?, and X2? with a lag of 1 to 2 and linear trend in the data, and an intercept but no trend in the cointegrating equation is assumed as exogenous variables.
See “References” for details on panel cointegration testing. See also Pool::uroot.
