Object Reference : Object View and Procedure Reference : Pool
makestats
Create and save series of descriptive statistics computed from a pool object.
pool_name.makestats(options) pool_series1 [pool_series2 ...] @ stat_list
You should provide options, a list of series names, an “@” separator, and a list of command names for the statistics you wish to compute. The series will have a name with the cross-section identifier “?” replaced by the statistic command.
Options in parentheses specify the sample to use to compute the statistics
i
Use individual sample.
c (default)
Use common sample.
b
Use balanced sample.
o
Force the overwrite of the computed statistics series if they already exist. The default creates a new series using the next available names.
prompt
Command names for the statistics to be computed
obs
Number of observations.
mean
Mean.
med
Median.
var
Variance.
sd
Standard deviation.
skew
Skewness.
kurt
Kurtosis.
jarq
Jarque-Bera test statistic.
min
Minimum value.
max
Maximum value.
pool1.makestats gdp_? edu_? @ mean sd
computes the mean and standard deviation of the GDP_? and EDU_? series in each period (across the cross-section members) using the default common sample. The mean and standard deviation series will be named GDP_MEAN, EDU_MEAN, GDP_SD, and EDU_SD.
pool1.makestats(b) gdp_? @ max min
Computes the maximum and minimum values of the GDP_? series in each period using the balanced sample. The max and min series will be named GDP_MAX and GDP_MIN.
See “Pooled Time Series, Cross-Section Data” for details on the computation of these statistics and a discussion of the use of individual, common, and balanced samples in pool.
See also Pool::describe.
