Object Reference : Object View and Procedure Reference : Series
prophet
Performs Facebook’s Prophet forecasting on the underlying series.
Prophet requires the Prophet Python library installed with EViews.
series_name.prophet(options) forecast_name [lower_name upper_name]
Enter a name for the forecast series, and optionally, a name for the lower and upper bounds of the forecast.
cpscale=number
Set the change point prior scale.
growth=arg
Set the growth type. arg can be “linear” (default) or “log”.
season=arg
Set the seasonality type. arg can be “add” (additive, default) or “mult” (multiplicative).
f=arg
Out-of-forecast-sample fill behavior: “actual” (fill observations outside the forecast sample with actual values for the fitted variable), “na” (fill observations outside the forecast sample with missing values, default), or “forc” (fill training-data observations with in-sample forecasts, and other data with NA).
prompt
Forecast sample options
The forecast sample will start at the observation immediately after the estimation sample (the current workfile sample). The forecast endpoint is given by either:
forclen=int
Number of periods to forecast.
forc=“date”
Specify the date of the forecast end point.
If omitted, the end point will be the end of the workfile range.
elecdmd.prophet(f=actual) elec_f elec_l elec_u
This will execute the Facebook Prophet routine on the ELECDMD series, inserting the actual values for out-of-forecast sample observations. The forecasted values will be stored in the new series ELEC_F, with the lower and upper bounds to the forecast being stored in ELEC_L and ELEC_U respectively.
See “Facebook Prophet Forecasting”.
