Change the vertical indentation size for objects in the spool.
spool_name.vertindent object_arg size_arg
where object_arg is the name or the position of a specific object to which you wish to apply indenting, and size_arg is an new indentation in virtual inches.
spool01.vertindent 1 0.02
spool01.vertindent tab1 0.02
change the indentation for the first object and for TAB1 to 0.02 virtual inches.
To refer to a child object of a spool, you must specify the object’s path. For instance, given a spool SPOOL01 containing the spool SP1 which in turn contains the graph G2:
spool01.vertindent sp1/g 0.03
also changes the vertical indentation of G2 in the embedded spool SP1 to 0.03 virtual inches, while
spool01.vertindent sp1 0.03
sets the indentation for SP1 to 0.03.
For additional discussion of spools see
“Spool Objects”.
