Changes the width (and height) of objects in the spool.
spool_name.width(options) [size_arg]
where
size_arg is an optional size in virtual inches. By default, widths will be set for all objects in the spool, if possible (
i.e., the graph object is not specified as fixed width, and the width is within limits defined by the current display mode; see
Spool::graphmode and
Spool::tablemode, for details).
Heights are set proportional to the width to maintain the original aspect ratio.
If size_arg is not provided, the objects will be set to their default sizes.
obj=arg | where arg is the name or the position of a specific object or embedded spool to which you wish to apply sizing. |
type=arg | where arg specifies a restricted subset of objects to be resized: “graph”, “table”, “text”. |
If the specified object is an embedded spool, all of its objects will be sized accordingly.
spool01.width 1
resizes all objects in the spool to 1 virtual inch, while
spool01.width(obj=1) 2
spool01.width(obj=tab1) 2
changes the widths of the first object and TAB1 to 2 virtual inches. The heights of the objects will change proportionately.
resets the sizes of the objects to their defaults.
To refer to a child object of a spool, you must specify the object’s path. For instance, given a spool SPOOL01 containing the spool SP1 which in turn contains the graph G2:
spool01.width(obj=sp1/g2) 2
also changes the width of G2 in the embedded spool SP1 to 2 virtual inches, while
spool01.width(obj=sp1) 3
sets the width for all of the objects in SP1 to 3 virtual inches.
spool01.width(type=graph) 2
sets the widths of graphs to 2 virtual inches.
For additional discussion of spools see
“Spool Objects”.
