String
String object. String objects may be used in standard EViews expressions in place of string literals.
String Declaration
To declare a string object, use the keyword string, followed by a name, an “=” sign and a text string.
String Views
display display table, graph, or spool in object window.
list list view display of the string.
String Procs
copy creates a copy of the string.
olepush push updates to OLE linked objects in open applications.
setattr set the value of an object attribute.
String Data Members
String values
@attr("arg") string containing the value of the arg attribute, where the argument is specified as a quoted string.
@description string containing the String object’s description (if available).
@detailedtype string with the object type: “STRING”.
@displayname string containing the String object’s display name. If the String has no display name set, the name is returned.
@name string containing the String object’s name.
@remarks string containing the String object’s remarks (if available).
@type string with the object type: “STRING”.
@updatetime string representation of the time and date at which the String was last updated.
String Examples
You can declare a string and examine its contents:
string st="Hello world"
show st
