Object Reference : Object View and Procedure Reference : System
garch
Conditional variance/covariance of (G)ARCH estimation.
Displays the conditional variance, covariance or correlation of a system estimated by ARCH.
system_name.garch(options) [arg1, arg2, ...]
The optional arguments following the keyword indicate which endogenous variable to include. If no argument is provided, all variables in the system will be included.
cor
Display correlation.
cov (default)
Display covariance.
var
Display only variance.
sd
Display only standard deviation.
graph (default)
Display data in graph.
mat
Display data in matrix format.
list
Display data in list format.
smpl=arg
Date to return conditional covariance value.
pre
Include presample data (used with the mat option only).
prompt
p
Print the graph
sys1.garch(cor)
displays the conditional correlation graph of SYS1.
ARCH estimation is described in “ARCH and GARCH Estimation”.
