Object Reference : Object View and Procedure Reference : System
qstats
Multivariate residual autocorrelation Portmanteau tests.
system_name.qstats(h, options)
You must specify the highest order of lag h to test for serial correlation .
maxlag=arg
Maximum lag in system specification (default=0).
chol
Standardized residuals factorized using the inverse of Cholesky factor of the (conditional) covariance matrix (for system ARCH).
cor
Standardized residuals factorized using the inverse square root of the (conditional) correlation matrix (for system ARCH).
cov
Standardized residuals factorized using the inverse square root of the (conditional) covariance matrix (for system ARCH).
prompt
p
Print the Portmanteau test results.
show sys1.qstats(l0)
displays the portmanteau tests for lags up to 10.
See “Diagnostic Views” for a discussion of the Portmanteau tests and other VAR diagnostics.
See Var::arlm for a related multivariate residual serial correlation LM test.
