Userobj
Userobj (user-defined object).
User Object Declaration
userobj declare an empty, unregistered user object.
A simple, non-registered, user object is created by simply using the userobj command followed by the name of the user object:
userobj myuserobject
User Object Views
Although a registered user object may have user-defined views available, all user objects have the following built-in views.
display display table, graph, or spool output in the user object window.
label display or change the label view of a user object.
members display a list of the members of a user object.
User Object Procs
Although a registered user object may have user-defined procs available, all user objects have the following built-in procs.
add add a data or object member to the user object.
clear remove all members from the user object.
copy creates a copy of the user object.
drop drop a data or object member from the user object.
extract display or copy a data member from the user object.
olepush push updates to OLE linked objects in open applications.
setattr set the value of an object attribute.
User Object Data Members
Although user objects can have user-defined data members, the following built-in data members also exist for all user objects.
String values
@attr("arg") string containing the value of the arg attribute, where the argument is specified as a quoted string.
@description string containing the user object’s description (if available).
@detailedtype string with the object type: “USEROBJ”.
@displayname string containing the user object’s display name. If the user object has no display name set, the name is returned.
@members space delimited list of all the user-defined members currently stored inside the user object.
@name string containing the user object’s name.
@remarks string containing the user object’s remarks (if available).
@type string with the object type: “USEROBJ”.
@updatetime string representation of the time and date at which the user object was last updated.
Scalar values
@hasmember(“name”) returns a 1 or a 0 depending on whether the user object has a data member called name.
