fit |
g | Graph the forecasts in individual graphs - one per dependent variable. |
m | Graph the forecasts in a combined graph. |
e | Produce the forecast evaluation table. |
f = arg (default= “actual”) | Out-of-forecast-sample fill behavior: “actual” (fill observations outside the forecast sample with actual values for the fitted variable), “na” (fill observations outside the forecast sample with missing values). |
p | Print view. |
streps=integer | Number of simulation repetitions. Only applicable if a se_pattern is provided. |
f=number | Fraction of failed repetitions before stopping. Only applicable if a se_pattern is provided. |
classical | Perform classical forecasting – forecast based upon the posterior means of the coefficients as if they were calculated from a classical VAR. If omitted Bayesian sampling is used. |
mean | Store the mean of the draws from the sampler. If omitted the median is stored. |
draws=integer (default= 100000) | Number of draws. |
burn=arg (default=0.1) | Proportion of initial draws to discard. |
seed=integer | Random number seed. |
dropunstable | Drop any draws that produce unstable coefficients. |
dgraph | Produce distribution graphs. |
fangraph | Produce fan graphs. |
page=arg | Store the individual draws in a new page. |
usemean | Use posterior mean as the point estimate. The posterior median is used if usemean is not included in the options list. |
showci | Show credibility intervals (bands). |
cilevels = arg (default = "0.95") | Set credibility levels. For multiple levels, enter a space-delimited list of values surrounded by quotation marks, e.g., "0.3 0.5 0.8". |
uselines | Use lines instead of shading for credibility intervals. |
seed = int | Set the random seed. EViews will generate a seed if one is not specified. |
rng = arg (default = “kn” or method set via rndseed) | Set random number generator type. Available types are: improved Knuth generator (“kn”), improved Mersenne Twister (“mt”), Knuth’s (1997) lagged Fibonacci generator used in EViews 4 (“kn4”), L’Ecuyer’s (1999) combined multiple recursive generator (“le”), Matsumoto and Nishimura’s (1998) Mersenne Twister used in EViews 4 (“mt4”). |
