Object Reference : Object View and Procedure Reference : Var
makergmprobs
Save the regime probabilities for switching VAR in series in the workfile.
var_name.makergmprobs(options) series_names
where var_name is the name of an switching VAR object. The series to be saved should be listed following the command name and options, with one name per regime for one up to the number of estimated regimes.
type=arg (default=“pred”)
Type of regime probability to compute: one-step ahead predicted (“pred”), filtered (“filt”), smoothed (“smooth”).
n=arg
(optional) Name of group to contain the saved regime probabilities.
prompt
var var1.switchls(type=markov) y1 y2 y3
var1.makergmprobs r1 r2
saves the one-step ahead regime probabilities for the Markov switching regression estimated in VAR in series R1 and R2 in the workfile
var1.makergmprobs(type=filt) f1
saves the filtered probabilities for regime 1 in F1.
var1.makergmprobs(type=smooth, n=smoothed) s1 s2
saved the smoothed probabilities for both regimes in the series S1 and S2, and creates the group SMOOTHED containing S1 and S2.
See “Switching VAR” for discussion.
See also Var::rgmprobs.
