Object Reference : Object View and Procedure Reference : Var
residcor
Residual correlation matrix.
Displays the correlations of the residuals from each equation in the var object.
Note that for Bayesian VARs, this command will display the empirical residual correlation—the correlation of the residuals calculated from the posterior means of the coefficients.
var_name.residcor(options)
p
Print the correlation matrix.
var1.residcor
displays the residual correlation matrix of VAR1.
See also Var::residcov and Var::makeresids.
