Command Reference : Strings and Dates : Dates
Dates
Date Strings
Date Numbers
Date Formats
Date Format Components
Years
Semi-Annual
Quarters
Months
Weeks
Days
Time (Hours/Minutes/Seconds)
Delimiters
Translating between Date Strings and Date Numbers
Free-format Conversion
Converting Unambiguous Date Strings to Numbers
Converting Ambiguous Date Strings to Numbers
Converting Date Numbers to Strings
Formatted Conversion
Translating Ordinary Numbers into Date Numbers
Manipulating Date Numbers
Date Operators
Functions for Manipulating Dates
Extracting Information from Date Numbers
Special Date Functions
Free-format Conversion Formats
Day, month, year
Month in year
Period in year
Whole year
Free-format Conversion Details
Dates and Date Intervals
Incomplete Date Numbers
Two-digit Years
Implicit Period Notation
American vs. European dates
Time of Day
Time Zones
There are a variety of places in EViews where you may work with calendar dates. For most purposes, users need not concern themselves with the intricacies of working with dates. Simply enter your dates in familiar text notation and EViews will automatically interpret the string for you.
Those of you who wish to perform more sophisticated operations with dates will, however, need to understand some basic concepts.
In most settings, you may simply use text representations of dates, or date strings. For example, an EViews sample can be set to include only observations falling between two dates specified using date strings such as “May 11, 1997”, “1/10/1990” or “2001q1”. In these settings, EViews understands that you are describing a date and will interpret the string accordingly.
Date information may also be provided in the form of a date number. A date number is a numeric value with special interpretation in EViews as a calendar date. EViews allows you to convert date strings into date numbers which may be manipulated using a variety of tools. These tools allow you to perform standard calendar operations such as finding the number of days or weeks between two dates, the day of the week associated with a given day, or the day and time 36 hours from now.
The remainder of this section summarizes the use of dates in EViews. (See “Strings and Dates” for reference material.) There are several tasks that are central to working with dates:
• Translating between date strings and date numbers.
• Translating ordinary numbers into date numbers.
• Manipulating date numbers using operators and functions.
• Extracting information from date numbers.
Before turning to these tasks, we must first provide a bit of background on the characteristics of date strings, date numbers, and a special class of strings called date formats, which are sometimes employed when translating between the former.
Date Strings
Date strings are simply text representations of dates and/or times. Most of the conventional ways of representing days, weeks, months, years, hours, minutes, etc., as text are valid date strings.
To be a bit more concrete, the following are valid date strings in EViews:
"December 1, 2001"
"12/1/2001"
"Dec/01/01 12am"
"2001-12-01 00:00"
"2001qIV”
As you can see, EViews is able to handle a wide variety of representations of your dates and times. You may use everything from years represented in 1, 2, and 4-digit Arabic form (“1”, “01”, “99”, “1999”), to month names and abbreviations (“January”, “jan”, “Jan”), to quarter designations in Roman numerals (“I” to “IV”), to weekday names and abbreviations (“Monday”, “Mon”), to 12 or 24-hour representations of time (“11:12 pm”, “23:12”). A full list of the recognized date string components is provided in “Date Formats”.
It is worth noting that date string representations may be divided up into those that are unambiguous and those that are ambiguous. Unambiguous date strings have but a single interpretation as a date, while ambiguous date strings may be interpreted in multiple ways.
For example, the following dates may reasonably be deemed unambiguous:
"March 3rd, 1950"
"1980Q3"
"9:52PM"
while the following dates are clearly ambiguous:
"2/3/4"
"1980:2"
"02:04"
The first date string in the latter set is ambiguous because we cannot tell which of the three fields is the year, which is the month, and which is the day, since different countries of the world employ different orderings. The second string is ambiguous since we cannot determine the period frequency within the year. The “2” in the string could, for example, refer to the second quarter, month, or even semi-annual in the year. The final string is ambiguous since it could be an example of a time of day in “hour:minute” format (2:04 am), or a date in “year:period” notation (i.e., the fourth month of the year 2002) or “period:year” notation (i.e., the second month of 2004).
In settings where date input is required, EViews will generally accept date string values without requiring you to provide formatting information. It is here that the importance of the distinction between ambiguous and unambiguous date strings is seen. If the date string is unambiguous, the free-format interpretation of the string as a date will produce identical results in all settings. On the other hand, if the date string is ambiguous, EViews will use the context in which the date is being used to determine the most likely interpretation of the string. You may find that ambiguous date strings are neither interpreted consistently nor as desired.
These issues, and methods of getting around the problem of ambiguity, are explored in greater detail in “Translating between Date Strings and Date Numbers”.
Date Numbers
Date information is often held in EViews in the form of a date number. A date number is a double precision number corresponding to an instance in time, with the integer portion representing a specific day, and the decimal fraction representing time during the day.
The integer portion of a date number represents the number of days in the Gregorian proleptic calendar since Monday, January 1, A.D. 0001 (a “proleptic” calendar is a calendar that is applied to dates both before and after the calendar was historically adopted). The first representable day, January 1, A.D. 1 has an integer value of 0, while the last representable day, December 31, A.D. 9999, has an integer value of 3652058.
The fractional portion of the date number represents a fraction of the day, with resolution to the millisecond. The fractional values range from 0 (12 midnight) up to (but not including) 1 (12 midnight). A value of 0.25, for example, corresponds to one-quarter of the day, or 6:00 a.m.
It is worth noting that the time of day in an EViews date number is accurate up to a particular millisecond within the day, although it can always be displayed at a lower “precision” (larger unit of time). When date numbers are formatted to lower precisions, they are always rounded down to the requested precision and never rounded up. Thus, when displaying the week or month associated with a date number, EViews always rounds down to the beginning of the week or month.
Date Formats
Years
Semi-Annual
Quarters
Months
Weeks
Days
Delimiters
A date format string (or date format, for short) is a string made up of text expressions that describe how components of a date and time may be encoded in a date string. Date formats are used to provide an explicit description of a date string representation, and may be employed when converting between strings or numbers and date numbers.
Before describing date formats in some detail, we consider a simple example. Suppose that we wish to use the date string “5/11/1997” to represent the date May 11, 1997. The date format corresponding to this text representation is
"mm/dd/yyyy"
which indicates that we have, in order, the following components: a one or two-digit month identifier, a “/” separator, a one or two-digit day identifier, a “/” separator, and a 4-digit year identifier.
Alternatively, we might wish to use the string “1997-May-11” to represent the same date. The date format for this string is
"yyyy-Month-dd"
since we have a four-digit year, followed by the full name of the month (with first letter capitalized), and the one or two-digit day identifier, all separated by dashes.
Similarly, the ISO 8601 representation for 10 seconds past 1:57 p.m. on this date is “1997-05-11 13:57:10”. The corresponding format is
"yyyy-MM-DD HH:mi:ss"
Here, we have used the capitalized forms of “MM”, “DD”, and “HH” to ensure that we have the required leading zeros.
A full description of the components of a date format is provided below. Some of the more commonly used examples of date formats are listed in the options for the setformat object commands (see, for example, Table::setformat).
Years
Semi-Annual
Quarters
Months
Weeks
Days
Delimiters
A date format may contain one or more of the following string fragments corresponding to various date components. In most cases, there are various upper and lowercase forms of the format component, corresponding either to the presence or absence of leading zeros, or to the case of the string identifiers.
The following format strings are the basic components of a date format:
Years
Year formats use either two or four digit years, with or without leading zeros. The corresponding date format strings are:
• “yyyy” or “YYYY”: four digit year without/with leading zeros.
• “yy” or “YY”: two digit year without/with leading zeros.
• “year” or “YEAR”: synonym for “yyyy” and “YYYY”, respectively.
Semi-Annual
The semi-annual format corresponds to a single digit representing the period in the year:
• “s” or “S”: one digit half-year (1 or 2).
Quarters
Quarter formats allow for values entered in either standard (Arabic) or Roman numbers:
• “q” or “Q”: quarter number, always without leading zeros (1 to 4).
• “qr” or “QR”: quarter in Roman numerals following the case of the format string (“i” to “iv” or “I” to “IV”.)
Months
Month formats may represent two-digit month values with or without leading zeros, three-letter abbreviations for the month, or the full month name. The text identifiers may be all lowercase, all uppercase or “namecase” in which we capitalize the first letter of the month identifier. The corresponding format strings are given by:
• “mm” or “MM”: two-digit month without/with leading zeros.
• “mon”, “Mon”, or “MON”: three-letter form of month, following the case of the format string(“jan”, “Feb”, “MAR”).
• “month”, “Month”, or “MONTH”: full month name, following the case of the format string (“january”, “February”, “MARCH”).
Weeks
Week of the year formats may be specified with or without leading zeros:
• “ww” or “WW”: week of year (with first week starting from Jan 1st) without/with leading zeros.
Days
Day formats correspond to day of the year, business day of the year, day of the month, or day of the week, in various numeric and text representations.
• “ddd” or “DDD”: day of year without/with leading zeros.
• “bbb” or “BBB”: business day of year without/with leading zeros (only counting Monday-Friday).
• “dd” or “DD”: day of month without/with leading zeros.
• “day” or “DAY”: day of month with suffix, following the case of the format string (“1st”, “2nd”, “3RD”).
• “w” or “W”: weekday number (1-7) where 1 is Monday.
• “wdy”, “Wdy”, or “WDY”: three-letter weekday abbreviation, following the case of the format string (“Mon”, “Tue”, “WED”).
• “weekday”, “Weekday”, or “WEEKDAY”: full weekday name, following the case of the format string (“monday”, “Tuesday”, “WEDNESDAY”).
The time formats correspond to hours (in 12 or 24 hour format), minutes, seconds, and fractional sections, with or without leading zeros and with or without the AM/PM indicator where appropriate.
• “hh” or “HH”: hour in 24-hour format without/with leading zeros.
• “hm” or “HM”: hour in 12-hour format without/with leading zeros.
• “am” or “AM”: two letter AM/PM indicator for 12-hour format, following the case of the format string.
• “a” or “A”: single letter AM/PM indicator for 12-hour format, following the case of the format string.
• “mi” or “MI”: minute, always with leading zeros.
• “ss.s”, “ss.s”, “ss.ss”, or “ss.sss”: seconds and tenths, hundreths, and thousandths-of-a-second, with leading zeros. The capitalized forms of these formats (“SS”, “SS.S”, ...) yield identical results.
Delimiters
You may use text to delimit the date format components:
• “f” or “F”: use frequency delimiter taken from the active, regular frequency workfile page. The delimiter corresponds to the letter associated with the current workfile frequency (“a”, “m”, “q”, ..., “A”, “M”, “Q”, ...), following the case of the format string, or the colon (“:”), as determined by the Global Options setting (Options/General Options.../Date representation).
• “?”: when used in an input date format, skips a single character of the input string. In an output date format “?” will be passed to the output string.
On input, the”?” delimiter is useful for ignoring part of a date string or where a delimiter may be variable. For example, an input string "02:83" could be interpreted using the format "MM:YY" to capture both month and year, or the format "??:YY" to capture just the year.
• Other alphabetical characters are errors unless they are enclosed in square brackets e.g. “[Q]”, in which case they are passed through to the output (for example, the “standard-EViews” quarterly format is “YYYY[Q]Q”, where we use a four digit year identifier, followed by a “Q” delimiter/identifier, followed by a single digit for the quarter “1990Q2”).
• All other characters (e.g., punctuation) are passed through to the input or output without special interpretation.
There are times when it is convenient to work with date strings, and times when it is easier to work with date numbers.
For example, when we are describing or viewing a specific date, it is easier to use a “human readable” date string such as “2002-Mar-20”, “3/20/2002”, or “March 20, 2002 12:23 pm” than the date number 730928.515972.
Alternatively, since date strings are merely text representations of dates, working with date numbers is essential when manipulating calendar dates to find elapsed days, months or years, or to find a specific date and time 31 days and 36 hours from now.
Accordingly, translating between string representations of dates and date numbers is one of the more important tasks when performing advanced operations with dates in EViews. These translations occur in many places in EViews, ranging from the interpretation of date strings in sample processing, to the spreadsheet display of series containing date numbers, to the import and export of data from foreign sources.
In most settings, the translations take place automatically, without user involvement. For example, when you enter a sample command of the form
smpl 1990q1 2000q4
EViews automatically converts the date strings into a range of date numbers. Similarly, when you edit a series that contains date numbers, you typically will enter your data in the form of a date string such as
"2002-Mar-20"
which EViews will automatically translate into a date number.
In other cases, you will specifically request a translation by using the built-in EViews functions @datestr (to convert a date number to a string) and @dateval (to convert a date string to a date number).
For example, the easiest way to identify the date 1,000 days after May 1, 2000 is first to convert the string value “May 1, 2000” into a date number using @dateval, to manipulate the date number to find the value 1000 days after the original date, and finally to convert the resulting date number back into a string using @datestr. See also “Formatted Conversion” and “Manipulating Date Numbers” for additional details.
All translations between dates strings and date numbers involve one of two methods:
• First, EViews may perform a free-format conversion in which the date format is inferred from the string values, in some cases other contextual information.
• Second, EViews may perform a formatted conversion in which the string representation of the dates is provided explicitly via a date format.
For the most part, you should find that free-format conversion is sufficient for most needs. Nevertheless, in some cases the automatic handling of dates by EViews may not produce the desired results. If this occurs, you should either modify any ambiguous date formats, or specify an explicit formatted conversion to generate date numbers as necessary.
EViews will perform free-format conversions between date strings and numbers whenever: (1) there is an automatic translation between strings and numbers, or (2) when you use one of the translation functions without an explicit date format.
When converting from strings to numbers, EViews will produce a date number using the “most likely” interpretation of the date string. For the most part, you need not concern yourself with the details of the conversion, but if you require additional detail on specific topics (e.g., handling of date intervals, the implicit century cutoff for 2-digit years) see “Free-format Conversion Details”.
When converting from date numbers to strings, EViews will use the global default settings to determine the default date format, and will display all significant information in the date number.
The free-format conversion of unambiguous date strings (see “Date Strings”), to numbers will produce identical results in all settings. The date string:
"March 3rd, 1950"
will be interpreted as the third day of the third month of the year A.D. 1950, and will yield the date value 711918.0. Note that the date value is the smallest associated with the given date, corresponding to 12 midnight.
Similarly, the date string:
"1980Q3"
is interpreted as the first instance in the third quarter of 1980. EViews will convert this string into the date number representing the smallest date value in that quarter, 722996.0 (12 midnight on July 1, 1980).
If we specify a time string without a corresponding day,
"9:52PM"
the day portion of the date is set to 0 (effectively, January 1, A.D. 1), yielding a value of 0.91111111 (see “Incomplete Date Numbers”) for details.
Consider also the following ambiguous date string:
"1 May 03"
While this entry may appear to be ambiguous since the “03” may reasonably refer to either 1903 or 2003, EViews resolves the ambiguity by assuming that if the two-digit year is greater than or equal to 30, the year is assumed to be from the twentieth century, otherwise the year is assumed to be from the twenty first century (see “Two-digit Years” for discussion). Consequently free-format conversion of two-digit years will produce consistent results in all settings.
Converting from ambiguous date strings will yield context sensitive results. In cases involving ambiguity, EViews will determine the most likely translation format by examining surrounding data or applicable settings for clues as to how the date strings should be interpreted.
The following contextual information is used in interpreting ambiguous free-form dates:
• For implicit period notation (e.g., “1990:3”) the current workfile frequency is used to determine the period.
• Choosing between ambiguous “mm/dd” or “dd/mm” formats is determined by examining the values of related date strings (i.e., those in the same series), user-specified date/time display formats for a series or column of a spreadsheet, or by examining the EViews global setting for date display, (Options/General Options.../Date representation).
To fix ideas, we consider a few simple examples of the use of contextual information.
If you specify an ambiguous sample string, EViews will use the context in which the sample is used, the frequency of the workfile, to determine the relevant period. For example, given the sample statement
smpl 90:1 03:3
and a quarterly workfile, the sample will be set from 1990q1 to 2003q3. If the workfile is monthly, the sample will be set from January 1990 to March 2003.
Suppose instead that you are editing a series spreadsheet where your date numbers are displayed as dates strings using a specified format. In this setting, EViews allows you to enter your values as date strings, instead of having to enter the underlying date numbers. In this context, it is natural for EViews to use the current display format as a hint in interpreting ambiguous data. For example, if the current display format is set to “Month dd, YYYY” then an input of “2/3/4” or “@dateval("2/3/4")” will be interpreted as February the 3rd, 2004. On the other hand, if the current display format is set to “YYYY-MM-DD” then the same input will be interpreted as the March the 4th, 2002.
In settings where an entire series is provided to an EViews procedure, EViews is able to use all of the values in the series to aid in determining the underlying data format. For example, when an alpha series is provided as a date identifier for restructuring a workfile, EViews will first scan all the values of the series in order to decide on the most likely format of all of the data before converting the string in each element into a date number. If the first observation of the series is an ambiguous “2/3/4” but a later observation is “3/20/95” then the “2/3/4” will be interpreted as the 3rd of February 2004 since that is the only order of year, month and day that is consistent with the “3/20/95” observation.
Conversely, when generating new series values with a genr or series assignment statement, EViews processes observation individually and is therefore unable to obtain contextual information to aid in interpreting ambiguous date strings. In this case, EViews will use the global workfile setting for the Month/Day order in dates to determine the ordering of the days and months in the string.
For example, when the expression
series dnums = @dateval("2/3/4")
is used to generate a series containing date values, EViews will interpret the value as February 3, 2004, if the global setting is Month/Day/Year, and March 2, 2004, if the global setting is Day/Month/Year.
EViews provides the @datestr function to translate a date number to a date string. We describe the function in detail in “Formatted Conversion”, but for now, simply note that @datestr takes an optional argument describing the date format to be used when exporting the string. If the optional argument is not provided, EViews will perform a free-format conversion.
In performing the free-format conversion, EViews examines two pieces of information. First, the global default settings for the Month/Day order in dates will be used to determine the ordering of days and months in the string. Next, EViews examines the date values to be translated and looks for relevant time-of-day information.
If there is no relevant time-of-day information in the date numbers (e.g., the non-integer portions are all zero), EViews writes the string corresponding to the date using either the date format
"dd/mm/yyyy"
or
"mm/dd/yyyy”
with preference given to the order favored in the global settings.
If there is relevant time-of-day information, EViews will extend the date format accordingly. Thus, if days are favored in the ordering, and relevant hours (but not minutes and seconds) information is present, EViews will use
"dd/mm/yyyy hh"
while if hours-minutes are present, the format will be
"dd/mm/yyyy hh:mi"
and so forth.
While the free-format conversions will generally produce the desired results, there may be times when you want to exercise precise control over the conversion. EViews will perform a formatted conversion between date strings and date numbers whenever you use the @dateval or @datestr functions with the optional second argument specifying an explicit date format.
To convert a date string into a date number using a date format, you should use the @dateval function with two arguments. The first argument must be a valid date string, and the second must be the corresponding date format string. If you omit the optional second argument, EViews will perform a free-format conversion.
• @dateval(str[, fmt]): takes the string str and evaluates it to a date number using the optional date format string, fmt.
See @dateval.
A few simple examples will illustrate the wide range of string to date number conversions that are possible using @dateval and a date format. The simplest format strings involve the standard month/day/year date descriptions:
@dateval("12/1/1999", "mm/dd/yyyy")
will return the date number for December 1, 1999 (730088),
@dateval("12/1/1999", "dd/mm/yyyy")
returns the date number for January 12, 1999 (729765). Here we have changed the interpretation of the date string from “American” to “European” by reversing the order of the parts of the format string.
Likewise, we may find the first date value associated with a given period
@dateval("1999", "yyyy")
returns the value 729754.0 corresponding to 12 midnight on January 1, 1999, the first date value for the year 1999.
Conversion of an broad range of date strings is possible by putting together various date format string components. For example,
@dateval("January 12, 1999", "Month dd, yyyy")
returns the date number for 12 midnight on January 12, 1999 (729765), while
@dateval("99 January 12, 9:37 pm", "yy Month dd, hm:mi am")
yields the value 729765.900694 corresponding to the same date, but at 9:37 in the evening. In this example, the “hm:mi” corresponds to hours (in a 12 hour format, with no leading 0’s) and minutes, and the “am” indicates that there is an indicator for “am” and “pm”. See “Date Strings” and “Date Formats” for additional details.
To translate a date number to a date string using a date format, you should use the @datestr function with two arguments. The first argument must be a valid date number, and the second must be a date format string describing a string representation of the date.
• @datestr(date_val[, fmt]): converts the date number into a string, using the optional date format fmt. If a format is not provided, EViews will use a default method (see “Converting Date Numbers to Strings”).
See @datestr.
For example,
@datestr(730088,"mm/dd/yy")
will return “12/1/99”,
@datestr(730088,"DD/mm/yyyy")
will return “01/12/1999”, and
@datestr(730088,"Month dd, yyyy")
will return “December 1, 1999”, and
@datestr(730088,"w")
will produce the string “3”, representing the weekday number for December 1, 1999. See “Date Numbers” and “Date Formats” for additional details.
While date information is most commonly held in the form of date strings or date numbers, one will occasionally encounter data in which a date is encoded as a (non-EViews format) numeric value or values. For example, the first quarter of 1991 may be given the numeric representation of 1991.1, or the date “August 15, 2001” may be held in the single number 8152001, or in three numeric values 8, 15, and 2001.
The @makedate function is used to translate ordinary numbers into date numbers. It is similar to @dateval but is designed for cases in which your dates are encoded in one or more numeric values instead of date strings:
• @makedate(arg1[, arg2[,arg3]], fmt): takes the numeric values given by the arguments arg1, and optionally, arg2, etc. and returns a date number using the required format string, fmt. Only a subset of all date formats are supported by @makedate.
If more than one argument is provided, the arguments must be listed from the lowest frequency to the highest, with the first field representing either the year or the hour.
See @makedate.
The simplest form of @makedate involves converting a single number into a date or a time. The following are the supported formats for converting a single number into a date value:
• “yy” or “yyyy”: two or four-digit years.
• “yys” or “yyyys”: year*10 + half-year.
• “yy.s” or “yyyy.s”: year + half-year/10.
• “yyq” or “yyyyq”: year*10 + quarter.
• “yy.q” or “yyyy.q”: year + quarter/10.
• “yymm” or “yyyymm”: year*10 + month.
• “yy.mm” or “yyyy.mm”: year + month/10.
• “yyddd” or “yyyyddd”: year*1000 + day in year.
• “yy.ddd” or “yyyy.ddd”: year + day in year/1000.
• “yymmdd” or “yyyymmdd”: year*10000 + month*100 + day in month.
• “mmddyy”: month*10000 + day in month*100 + two-digit year.
• “mmddyyyy”: month*100000 + day in month*10000 + four-digit year.
• “ddmmyy”: day in month*10000 + month*100 + two-digit year.
• “ddmmyyyy”: day in month*1000000 + month*10000 + four-digit year.
The following formats are supported for converting a single number into intraday values:
• “hh”: hour in day (in 24 hour units)
• “hhmi”: hour*100 + minute.
• “hhmiss”: hour*10000 + minute*100 + seconds.
Note that the @makedate format strings are not case sensitive, since the function requires that all non-leading fields must have leading zeros where appropriate. For example, when using the format “YYYYMMDD”, the date March 1, 1992 must be encoded as 19920301, and not 199231, 1992031, or 1992301.
Let us consider some specific examples of @makedate conversion of a single number. You may convert a numeric value for the year into a date number using a format string to describe the year. The expressions:
@makedate(1999, "yyyy")
@makedate(99, "yy")
both return the date number 729754.0 corresponding to 12 midnight on January 1, 1999. Similarly, you may convert a numeric value into the number of hours in a day using expressions of the form,
@makedate(12, "hh")
Here, EViews will return the date value 0.5 corresponding to 12 noon on January 1, A.D. 1. While this particular date value is not intrinsically of interest, it may be combined with other date values to obtain the value for a specific hour in a particular day. For example using date arithmetic, we may add the 0.5 to the 729754.0 value (12 midnight, January 1, 1999) obtained above, yielding the date value for 12 noon on January 1, 1999. We consider these sorts of operations in greater detail in “Manipulating Date Numbers”.
If your number contains “packed” date information, you may interpret the various components using @makedate with an appropriate format string. For example,
@makedate(199003, "yyyymm")
@makedate(1990.3, "yyyy.mm")
@makedate(1031990, "ddmmyyyy")
@makedate(30190, "mmddyy")
all return the value 726526.0, representing March 1, 1990.
Cases where @makedate is used to convert more than one argument into a date or time are more limited and slightly more complex. The arguments must be listed from the lowest frequency to the highest, with the first field representing either the year or the hour, and the remaining fields representing sub-periods. The valid date format strings for the multiple argument @makedate are a subset of the date format strings, with components applied sequentially to the numeric arguments:
• “yy s” or “yyyy s”: two or four-digit year and half-year.
• “yy q” or “yyyy q”: year and quarter.
• “yy mm” or “yyyy mm”: year and month.
• “yy ddd” or “yyyy ddd”: year and day in year.
• “yy mm dd” or “yyyy mm dd”: year, month, and day in month.
Similarly, the valid formats for converting multiple numeric values into a time are:
• “hh mi”: hour*100 + minute.
• “hh mi ss”: hour*10000 + minutes*100 + seconds.
For convenience, the non-space-delimited forms of these format strings are also supported (e.g., “yymm”, and “hhmi”).
For example, the expressions,
@makedate(97, 12, 3, "yy mm dd")
@makedate(1997, 12, 3, "yyyymmdd")
will return the value 729360.0 corresponding to midnight on December 3, 1997. You may provide a subset of this information so that
@makedate(97, 12, "yymm")
returns the value 729358.0 representing the earliest date and time in December of 1997 (12 midnight, December 1, 1997). Likewise,
@makedate(1997, 37, "yyyy ddd")
yields the value 729060.0 (February 6, 1997, the 37th day of the year) and
@makedate(14, 25, 10, "hh mi ss")
returns the value 0.600810185 corresponding to 2:25:10 pm on January 1, A.D. 1.
It is worth pointing out that in the examples above, the numeric arguments are entered from lowest frequency to high, as required. The following example, in which days appear before months and years, is not a legal specification
@makedate(7, 10, 98, "dd mm yy")
and will generate an error reporting a “Bad date format”.
Lastly, we note that limitations on the date formats supported by @makedate imply that in some cases, you are better off working with strings and the @dateval function. In cases, where @makedate does not support a desired conversion, you should consider converting your numbers into strings, performing string concatenation, and then using the richer set of @dateval conversions to obtain the desired date values.
Date Operators
One of the most important reasons for holding your date information in the form of date numbers is so that you may perform sophisticated calendar operations.
Date Operators
Since date values are simply double precision numbers, you may perform standard mathematical operations using these values. While many operations such as division and multiplication do not preserve the notion of a date number, you may find addition and subtraction and relational comparison of date values to be useful tools.
If, for example, you add 7 to a valid date number, you get a value corresponding to the same time exactly seven days later. Adding 0.25 adds one-quarter of a day (6 hours) to the current time. Likewise, subtracting 1 gives the previous day, while subtracting 0.5 gives the date value 12 hours earlier. Taking the difference between two date values yields the number of days between the two values.
While using the addition and subtraction operators is valid, we strongly encourage you to use the EViews specialized date functions since they allow you to perform arithmetic at various frequencies (other than days), while taking account of irregularities in the calendar (see “Functions for Manipulating Dates”).
Similarly, while you may round a date number down to the nearest integer to obtain the first instance in the day, or you may round down to a given precision to find the first instance in a month, quarter or year, the built-in functions provide a set of simple, yet powerful tools for working with dates.
Note further that all of the relational operators are valid for comparing date numbers. Thus, if two date numbers are equal, the “=”, “>=”, and “<=” relational operators all return a 1, while the “<>”, “>”, and “<” comparison operators return a 0. If two date numbers are not equal, “<>” returns a 1 and “=” returns a 0. If the first date number is less than a second date number, the corresponding first date precedes the second in calendar time.
EViews provides several functions for manipulating dates that take date numbers as input and return numeric values that are also date numbers. These functions may be used when you wish to find a new date value associated with a given date number, for example, a date number 3 months before or 37 weeks after a given date and time.
The functions described below all take a time unit string as an argument. As the name suggests, a time unit string is a character representation for a unit of time, such as a month or a year. The valid time unit string values are: “A” or “Y” (annual), “S” (semi-annual), “Q” (quarters), “MM” (months), “WW” (weeks), “DD” (days), “B” (business days), “HH” (hours), “MI” (minutes), “SS” (seconds).
There are three primary functions for manipulating a date number:
• @dateadd(date1, offset[, u]): returns the date number given by date1 offset by offset time units as specified by the time unit string u. If no time unit is specified, EViews will use the workfile regular frequency, if available.
Suppose that the value of date1 is 730088.0 (midnight, December 1, 1999). Then we can add and subtract 10 days from the date by using the functions
@dateadd(730088.0, 10, "dd")
@dateadd(730088.0, -10, "dd")
which return 730098.0 (December 11, 1999) and (730078.0) (November 21, 1999). Note that these results could have been obtained by taking the original numeric value plus or minus 10.
The @dateadd function allows for date offsets specified in various units of time. For example, to add 5 weeks to the existing date, simply specify “W” or “WW” as the time unit string, as in
@dateadd(730088.0, 5, "ww")
which returns 730123.0 (January 5, 2000).
See @dateadd.
• @datediff(date1, date2[, u]): returns the number of time units between date1 and date2, as specified by the time unit string u. If no time unit is specified, EViews will use the workfile regular frequency, if available.
Suppose that date1 is 730088.0 (December 1, 1999) and date2 is 729754.0 (January 1, 1999), then,
@datediff(730088.0, 729754.0, "dd")
returns 334 for the number of days between the two dates. Note that this is result is simply the difference between the two numbers.
The @datediff function is more powerful in that it allows us to calculate differences in various units of time. For example, the expressions
@datediff(730088.0, 729754.0, "mm")
@datediff(730088.0, 729754.0, "ww")
return 11 and 47 for the number of months and weeks between the dates.
See @datediff.
• @datefloor(date1, u[, step]): finds the first possible date number in the given time unit, as in the first possible date value in the current quarter, with an optional step offset.
If step is omitted, the frequency will use a step of 1 so that by default, @datefloor will find the beginning of the period defined by the time unit.
Suppose that date1 is 730110.5 (12 noon, December 23, 1999). Then the @datefloor values
@datefloor(730110.5, "dd")
@datefloor(730110.5, "mm")
yield 730110.0 (midnight, December 23, 1999) and 730088.0 (midnight, December 1, 1999), since those are the first possible date values in the current day and month. Note that the first value is simply the integer portion of the original date number, but that the latter required more complex analysis of the calendar.
Likewise, we can find the start of any corresponding period by using different time units:
@datefloor(730098.5, "q")
@datefloor(730110.5, "y", 1)
returns 730027.0 (midnight, October 1, 1999), and 729754.0 (midnight, January 1, 1999. Notice that since the latter example used an offset value of 1, the result corresponds to the first date value for the year 1999, which is the start of the year following the actual value.
See @datefloor.
Given a date number you may wish to extract numeric values associated with a portion of the value. For example, you might wish to know the value of the month, the year, or the day in the year associated with a given date value. EViews provides the @datepart function to allow you to extract the desired information.
• @datepart(date1, u): returns a numeric part of a date value given by u, where u is a time unit string.
See @datepart.
Consider the date1 date value 730110.5 (noon, December 23, 1999). The @datepart values for
@datepart(730110.5, "dd")
@datepart(730110.5, "w")
@datepart(730110.5, "ww")
@datepart(730110.5, "mm")
@datepart(730110.5, "yy")
are 23 (day of the month), 1 (day in the week), 52 (week in the year), 12 (month in the year), and 99 (year), respectively.
Note that the numeric values returned from @datepart are not themselves date values, but may be used with @makedate to create date values.
In addition to the functions that convert strings or numbers into date values, EViews provides the following special ways to obtain one or more date values of interest.
• @now: returns the date number associated with the current time.
The remaining functions return information for each observation in the current workfile.
• @date: returns the date number corresponding to every observation in the current workfile.
• @year: returns the four digit year in which the current observation begins. It is equivalent to @datepart(@date, "YYYY")
• @quarter: returns the quarter of the year in which the current observation begins. It is equivalent to @datepart(@date, "Q").
• @month: returns the month of the year in which the current observation begins. It is equivalent to @datepart(@date, "MM").
• @day: returns the day of the month in which the current observation begins. It is equivalent to @datepart(@date, "DD").
• @weekday: returns the day of the week in which the current observation begins, where Monday is given the number 1 and Sunday is given the number 7. It is equivalent to @datepart(@date, "W").
• @hour: returns the current observation hour as an integer. For example, 9:30AM returns 9, and 5:15PM returns 17.
• @minute: returns the current observation minute as an integer. For example, 9:30PM returns 30.
• @second: returns the current observation second as an integer.
• @hourf: returns the current observation time as a floating point hour. For example, 9:30AM returns 9.5, and 5:15PM returns 17.25.
• @strdate(fmt): returns the set of workfile row dates as strings, using the date format string fmt. See “Date Formats” for a discussion of date format strings.
The @date function will generally be used to create a series containing the date value associated with every observation, or as part of a series expression involving date manipulation. For example:
series y = @date
series x = @dateadd(@date, 12, "ww")
which generates a series containing the date values for every observation, and the date values for every observation 12 weeks from the current values.
@strdate should be used when you wish to obtain the date string associated with every observation in the workfile—for example, to be used as input to an alpha series. It is equivalent to using the @datestr function on the date number associated with every observation in the workfile.
Additional series functions involving dates may be listed in “Workfile Functions”.
Day, month, year
Month in year
Period in year
Whole year
EViews supports the free-format conversion of a wide variety of date strings in which the string is analyzed for the most likely corresponding date.
Any of the following date string types are allowed:
Day, month, year
• “"YYYY-MM-DD"” (IEEE, with the date enclosed in double quotes)
• “dd/mm/yy” (if American, “mm/dd/yy” instead)
• “dd/mm/yyyy” (if American, “mm/dd/yyyy” instead)
• “yyyy/mm/dd”
• “dd/mon/yy”
• “dd/mon/yyyy”
• “yyyy/mon/dd”
• “ddmmyy” (if American, “mmddyy”)
• “ddmmyyyy” (if American, “mmddyyyy”)
The resulting date values correspond to the first instance in the day (12 midnight).
Month in year
• “mon/yy”
• “mon/yyyy”
• “yy/mon”
• “yyyy/mon”
The results are rounded to the first instance in the month (12 midnight of the first day of the month).
Period in year
• “yyyy[S|Q|M|W|B|D|T|F|:]period”
• “yy[S|Q|M|W|B|D|T|F|:]period”
The date value is rounded to the first instance in the period in the year
Whole year
• “yyyy[A]”. The “A” is generally optional, but required if current WF is undated.
• “yy[A]”. The “A” is generally optional, but required if current WF is undated.
The date value is rounded to the first instance in the year (12 midnight on January 1).
Two-digit Years
Time of Day
Note that the following conventions may be used in interpreting ambiguous free-form dates.
A date in EViews is generally taken to represent a single point in calendar time. In some contexts, however, a date specification is used to refer to a range of values contained in a time, which can be referred to as an interval.
When a date specification is treated as an interval, the precision with which the date is specified is used to determine the duration of the interval. For example, if a full day specification is provided, such as “Oct 11 1980”, then the interval is taken to run from midnight at the beginning of the day to just before midnight at the end of the day. If only a year is specified, such as “1963”, then the interval is taken to run from midnight on the 1st of January of the year to just before midnight on the 31st of December at the end of the year.
An example where this is used is in setting the sample for a workfile. In this context, pairs of dates are provided to specify which observations in the workfile should be included in the sample. The pairs of dates are provided are processed as intervals, and the sample is defined to run from the start of the first interval to the end of the second interval. As an example, if the sample “1980q2 1980q2” is specified for a daily file, the sample will include all observations from April 1st 1980 to June 30th 1980 inclusive.
An EViews date number can be used to represent both a particular calendar day, and a particular time of day within that day. If no time of day is specified, the time of day is set to midnight at the beginning of the day.
When no date is specified, the day portion of a date is effectively set to 1st Jan A.D. 1. For example, the date string “12 p.m.” will be translated to the date value 0.5 representing 12 noon on January 1, A.D. 1. While this particular date value is probably not of intrinsic interest, it may be combined with other information to obtain meaningful values. See “Manipulating Date Numbers”
Two-digit Years
In general, EViews interprets years containing only two digits as belonging to either the twentieth or twenty-first centuries, depending on the value of the year. If the two digit year is greater than or equal to 30, the year is assumed to be from the twentieth century and a century prefix of “19” is added to form a four digit year. If the number is less than 30, the year is assumed to be from the twenty first century and a century prefix of “20” is added to form a four digit year.
Note that if you wish to refer to a year after 2029 or a year before 1930, you must use the full four-digit year identifier.
Because this conversion to four digit years is generally performed automatically, it is not possible to specify years less than A.D. 100 using two digit notation. Should the need ever arise to represent these dates, such two digit years can be input directly by specifying the year as a four digit year with leading zeros. For example, the 3rd of April in the year A.D. 23 can be input as “April 3rd 0023”.
In implicit period notation (e.g., “1990:3”), the current workfile frequency is used to determine the period.
When performing a free-format conversion in the absence of contextual information sufficient to identify whether data are provided in “mm/dd” or “dd/mm” format, the global workfile setting for the Options/Dates & Frequency Conversion.../Month/Day order in dates ( “Date Representation”) will be used to determine the ordering of the days and months in the string.
For example, the order of the months and years is ambiguous in the date pair:
1/3/91 7/5/95
so EViews will use the default date settings to determine the desired ordering. We caution you, however, that using default settings to define the interpretation of date strings is not a good idea since a given date string may be interpreted in different ways at different times if your settings change. You may instead use the IEEE standard format, “YYYY-MM-DD” to ensure consistent interpretation of your daily date strings. The presence of a dash in the format means that you must enclose the date in quotes for EViews to accept this format. For example:
smpl "1991-01-03" "1995-07-05"
will always set the sample to run from January 3, 1991 and July 5, 1995.
Time of Day
Free-format dates can also contain optional trailing time of day information which must follow the pattern:
hh[[[[[:mi:]ss].s]s]s][am|AM|pm|PM]
where “[]” encloses optional portions or the format and “|” indicates one of a number of possibilities. In addition, either the “am” or “pm” field or an explicit minute field must be provided for the input to be recognized as a time. An hour by itself is generally not sufficient.
The time of day in an EViews date is accurate up to a particular millisecond within the day, although any date can always be displayed at a lower precision. When displaying times at a lower precision, the displayed times are always rounded down to the requested precision, and never rounded up.
When both a day and a time of day are specified as part of a date, the two can generally be provided one after the other with the two fields separated by one or more spaces. If, however, the date is being used in a context where EViews does not permit spaces between input fields, a single letter “t” can also be used to separate the day and time so that the entire date can be contained in a single word, e.g. “1990-Jan-03T09:53”.
Time Zones
There are a related set of functions that you may use that provide information on time-zones: @localt, @tz, @tzlist, @tzspec, and @utc.
