Command Reference : Function Reference : Function Reference: C
@cumbquantile
Cumulative quantiles of a series.
Increasing samples calculation of the quantile value where approximately 100*q percent of the data is less than or equal to the value,
Syntax: @cumbquantile(x, q, [s])
x: series
q: number, series
s: (optional) sample string or object
Return: series
• The quantile value q must satisfy .
• The cumulative quantiles are computed using the Rankit-Cleveland definition of the empirical distribution function: .
To compute the cumulative backward quantile for observation find , the smallest rank such that:
where the order statistics represent data for the observations (), ordered from low to high, and is the last period. For purposes of computing , tied ranks are assumed to take the last tied value.
Then the quantile is computed as:
where the interpolating constant is
for the smallest integer where . In the leading case where there are no tied values, .
This function is panel aware.
show @cumbquantile(x, 0.1)
generates a linked series of the backward cumulative 10th percentile of the series x.
See also @cumbmedian.
For the forward variant of this function, see @cumquantile.
