Command Reference : Function Reference : Function Reference: C
@cumquantile
Cumulative quantiles of a series.
Increasing samples calculation of the quantile value where approximately 100*q percent of the data is less than or equal to the value,
Syntax: @cumquantile(x, q, [s])
x: series
q: number, series
s: (optional) sample string or object
Return: series
• The quantile value q must satisfy .
• The cumulative quantiles are computed using the Rankit-Cleveland definition of the empirical distribution function: for observation , .
To compute the cumulative quantile for observation find , the smallest rank such that:
where the order statistics represent data from the beginning of the workfile or sample s, up to the current observation (), ordered from low to high. For purposes of computing , tied ranks are assumed to take the last tied value.
Then the quantile is computed as
where the interpolating constant is
for the smallest integer where . In the leading case where there are no tied values, .
This function is panel aware.
show @cumquantile(@nrnd, 0.975)
generates a linked series that converges in probability to 1.95996... (the 97.5th percentile of the standard normal distribution).
See also @cummedian.
For the backward variant of this function, see @cumbquantile.
