Command Reference : Function Reference : Function Reference: D
@dcumdn
Difference of the cumulative process of negative (below threshold) changes.
Compute the difference of the partial sum process of negative (below the threshold y) changes in the series x beginning in the specified date.
Syntax: @dcumdn(x, d[, y, s])
x: series
d: string
y: (optional) number
s: (optional) sample string or object
Return: series
Consider the partial sum decomposition of a variable given a initial value as where , , and are the partial sum processes of the differences for positive, negative, and zero changes in relative to the threshold y:
The function returns the negative accumulation for the current or specified sample.
• The date d string specification determines .
• Values for dates prior to d will be NAs.
• The optional argument specifies the threshold value. By default .
This function is panel aware.
The code below produces a graph of @cumdn and @dcumdn applied on the sine wave x.
wfcreate u 50
series x = @sin(@pi*@trend/4)
group g @cumdn(x,1) @dcumdn(x,1)
g.line
See also @cumdp, @cumdn, @cumdz, @dcumdp, and @dcumdz.
