Command Reference : Function Reference : Function Reference: I
@imaxes
Indices of maximums values (multiple).
Returns n workfile or row indices corresponding to the n-th maximums of the elements of x.
Syntax: @imaxes(x, n[, s])
x: data object
n: integer
Return: vector
If n is not an integer, the integer floor will be used.
Return the actual workfile or row indices corresponding to
where the order statistics represent the data ordered from low to high. The indices will be ordered from high to low of the corresponding values.
Let x be a series of length 5 whose elements are 1, 3, 5, 4, 2, 5.
Then
= @imaxes(x, 1)
returns a vector containing (3, 6) the set of indices corresponding to the value 5.
Similarly
= @imaxes(x, 2)
returns a vector containing (3, 6, 4) the set of indices corresponding to the values 5 and 4.
See also @max, @maxes, @imin, and @imins.
