Command Reference : Function Reference : Function Reference: I
@imin
Index of minimum value.
Workfile or row index corresponding to the minimum of the elements of x.
Syntax: @imin(x[, s])
x: data object
s: (optional) sample string or object when x is a series or alpha and assigning to a series
Return: number
Given the order statistics representing the data ordered from low to high, we return the actual workfile or row index corresponding to
where the order statistics represent the data ordered from low to high.
Let x be a series of length 5 whose elements are 1, 3, 5, 4, 2. Then
= @imin(x)
returns 1.
See also @min, @mins, @imins, @max, @imax, @imaxes, @maxes.
