Command Reference : Function Reference : Function Reference: P
@pctiles
Percentile values.
Determine the percentile associated with each value.
Syntax: @pctiles(x[, z, s])
x: series, vector, matrix
z: (optional) string literal
s: (optional) sample string or object when x is a series and assigning to a series
Return: series
If is the ranking associated with observation of , the percentile is given by
The z option controls tie-handling with rankings handled according to the setting:
• “i” (ignore), “f” (first), “l” (last), “a” (average - default), “r” randomize.
Let x be a vector of length 4 with elements 1, 2, 3, 4. Then
= @pctiles(x)
returns a vector whose elements are 25, 50, 75, 100.
matrix y = @mnrnd(200, 4)
matrix pct1 = @pctiles(y, "a")
matrix pct2 = 100 * @ranks(y, "a") / @obs(y)
compute the percentiles of the randomly generated matrix Y directly using @pctiles and indirectly using @ranks. Both PCT1 and PCT2 are matrices where each element is the percentile of the corresponding element of Y amongst all elements.
See also @quantile.
