Command Reference : Function Reference : Function Reference: Q
@quantile
Empirical quantile.
Compute the quantile value where approximately 100*q percent of the data is less than or equal to the value,
Syntax: @quantile(x, q[, m, s])
x: series, vector, matrix
q: number, series, vector, matrix
m: (optional) string
s: (optional) sample string or object when x is a series and assigning to a series
Return: number
• The quantile value q must satisfy .
• m is an optional string controlling the method of calculating the empirical distribution function: “b” (Blom), “r” (Rankit-Cleveland), “o” (Ordinary), “t” (Tukey), “v” (van der Waerden), “g” (Gumbel). The default value is “r”.
Rankit-Cleveland (default)
Ordinary
Van der Waerden
Blom
Tukey
Gumbel
To compute the -quantile, first find , the smallest rank such that,
where the order statistics represent data for the observations ordered from low to high, and is the assumed empirical distribution function. For purposes of computing , tied ranks are assumed to take the last tied value.
Then the quantile is computed as
where the interpolating constant is
for the smallest integer where . In the leading case where there are no tied values, .
= @quantile(x, 0.5)
returns the median of the series x.
= @quantile(x, 0.1)
returns the first decile (10th percentile) of the series x.
See also @pctiles.
