User’s Guide : Basic Single Equation Analysis : Instrumental Variables and GMM : Generalized Method of Moments
The GMM Estimator
Choice of Weighting Matrix
Weighting Matrix Iteration
Linear Equation Weight Updating
Non-linear Equation Weight Updating
Coefficient Covariance Calculation
Conventional Estimators
Windmeijer Estimator
Weighted GMM
Estimation by GMM in EViews
We offer here a brief description of the Generalized Method of Moments (GMM) estimator, paying particular attention to issues of weighting matrix estimation and coefficient covariance calculation. Or treatment parallels the excellent discussion in Hayashi (2000). Those interested in additional detail are encouraged to consult one of the many comprehensive surveys of the subject.
The GMM Estimator
The starting point of GMM estimation is the assumption that there are a set of moment conditions that the -dimensional parameters of interest, should satisfy. These moment conditions can be quite general, and often a particular model has more specified moment conditions than parameters to be estimated. Thus, the vector of moment conditions may be written as:
(23.24)
In EViews (as in most econometric applications), we restrict our attention to moment conditions that may be written as an orthogonality condition between the residuals of an equation, , and a set of instruments :
(23.25)
The traditional Method of Moments estimator is defined by replacing the moment conditions in Equation (23.24) with their sample analog:
(23.26)
and finding the parameter vector which solves this set of equations.
When there are more moment conditions than parameters (), the system of equations given in Equation (23.26) may not have an exact solution. Such as system is said to be overidentified. Though we cannot generally find an exact solution for an overidentified system, we can reformulate the problem as one of choosing a so that the sample moment is as “close” to zero as possible, where “close” is defined using the quadratic form:
(23.27)
as a measure of distance. The possibly random, symmetric and positive-definite matrix is termed the weighting matrix since it acts to weight the various moment conditions in constructing the distance measure. The Generalized Method of Moments estimate is defined as the that minimizes Equation (23.27).
As with other instrumental variable estimators, for the GMM estimator to be identified, there must be at least as many instruments as there are parameters in the model. In models where there are the same number of instruments as parameters, the value of the optimized objective function is zero. If there are more instruments than parameters, the value of the optimized objective function will be greater than zero. In fact, the value of the objective function, termed the J-statistic, can be used as a test of over-identifying moment conditions.
Under suitable regularity conditions, the GMM estimator is consistent and asymptotically normally distributed,
(23.28)
The asymptotic covariance matrix of is given by
(23.29)
for
(23.30)
where is both the asymptotic variance of and the long-run covariance matrix of the vector process.
In the leading case where the are the residuals from a linear specification so that , the GMM objective function is given by
(23.31)
and the GMM estimator yields the unique solution . The asymptotic covariance matrix is given by Equation (23.27), with
(23.32)
It can be seen from this formation that both two-stage least squares and ordinary least squares estimation are both special cases of GMM estimation. The two-stage least squares objective is simply the GMM objective function multiplied by using weighting matrix . Ordinary least squares is equivalent to two-stage least squares objective with the instruments set equal to the derivatives of , which in the linear case are the regressors.
An important aspect of specifying a GMM estimator is the choice of the weighting matrix, . While any sequence of symmetric positive definite weighting matrices will yield a consistent estimate of , Equation (23.29) implies that the choice of affects the asymptotic variance of the GMM estimator. Hansen (1992) shows that an asymptotically efficient, or optimal GMM estimator of may be obtained by choosing so that it converges to the inverse of the long-run covariance matrix :
(23.33)
Intuitively, this result follows since we naturally want to assign less weight to the moment conditions that are measured imprecisely. For a GMM estimator with an optimal weighting matrix, the asymptotic covariance matrix of is given by
(23.34)
Implementation of optimal GMM estimation requires that we obtain estimates of . EViews offers four basic methods for specifying a weighting matrix:
• Two-stage least squares: the two-stage least squares weighting matrix is given by where is an estimator of the residual variance based on an initial estimate of . The estimator for the variance will be or the no d.f. corrected equivalent, depending on your settings for the coefficient covariance calculation.
• White: the White weighting matrix is a heteroskedasticity consistent estimator of the long-run covariance matrix of based on an initial estimate of .
• HAC - Newey-West: the HAC weighting matrix is a heteroskedasticity and autocorrelation consistent estimator of the long-run covariance matrix of based on an initial estimate of .
• User-specified: this method allows you to provide your own weighting matrix (specified as a sym matrix containing a scaled estimate of the long-run covariance ).
For related discussion of the White and HAC - Newey West robust standard error estimators, see “Robust Standard Errors”.
As noted above, both the White and HAC weighting matrix estimators require an initial consistent estimate of . (Technically, the two-stage least squares weighting matrix also requires an initial estimate of , though these values are irrelevant since the resulting does not affect the resulting estimates).
Accordingly, computation of the optimal GMM estimator with White or HAC weights often employs a variant of the following procedure:
1. Calculate initial parameter estimates using TSLS
2. Use the estimates to form residuals
3. Form an estimate of the long-run covariance matrix of , , and use it to compute the optimal weighting matrix
4. Minimize the GMM objective function with weighting matrix
(23.35)
with respect to to form updated parameter estimates.
We may generalize this procedure by repeating steps 2 through 4 using as our initial parameter estimates, producing updated estimates . This iteration of weighting matrix and coefficient estimation may be performed a fixed number of times, or until the coefficients converge so that to a sufficient degree of precision.
An alternative approach due to Hansen, Heaton and Yaron (1996) notes that since the optimal weighting matrix is dependent on the parameters, we may rewrite the GMM objective function as
(23.36)
where the weighting matrix is a direct function of the being estimated. The estimator which minimizes Equation (23.36) with respect to has been termed the Continuously Updated Estimator (CUE).
For equations that are linear in their coefficients, EViews offers three weighting matrix updating options: the N-step Iterative, the Iterate to Convergence, and the Continuously Updating method.
As the names suggests, the N-Step Iterative method repeats steps 2-5 above times, while the Iterate to Convergence repeats the steps until the parameter estimates converge. The Continuously Updating approach is based on Equation (23.36).
Somewhat confusingly, the N-Step Iterative method with a single weight step is sometimes referred to in the literature as the 2-step GMM estimator, the first step being defined as the initial TSLS estimation. EViews views this as a 1-step estimator since there is only a single optimal weight matrix computation.
For equations that are non-linear in their coefficients, EViews offers five different updating algorithms: Sequential N-Step Iterative, Sequential Iterate to Convergence, Simultaneous Iterate to Convergence, 1-Step Weight Plus 1 Iteration, and Continuously Updating. The methods for non-linear specifications are generally similar to their linear counterparts, with differences centering around the fact that the parameter estimates for a given weighting matrix in step 4 must now be calculated using a non-linear optimizer, which itself involves iteration.
All of the non-linear weighting matrix update methods begin with obtained from two-stage least squares estimation in which the coefficients have been iterated to convergence.
The Sequential N-Step Iterative procedure is analogous to the linear N-Step Iterative procedure outlined above, but with the non-linear optimization for the parameters in each step 4 iterated to convergence. Similarly, the Sequential Iterate to Convergence method follows the same approach as the Sequential N-Step Iterative method, with full non-linear optimization of the parameters in each step 4.
The Simultaneous Iterate to Convergence method differs from Sequential Iterate to Convergence in that only a single iteration of the non-linear optimizer, rather than iteration to convergence, is conducted in step 4. The iterations are therefore simultaneous in the sense that each weight iteration is paired with a coefficient iteration.
1-Step Weight Plus 1 Iteration performs a single weight iteration after the initial two-stage least squares estimates, and then a single iteration of the non-linear optimizer based on the updated weight matrix.
The Continuously Updating approach is again based on Equation (23.36).
Having estimated the coefficients of the model, all that is left is to specify a method of computing the coefficient covariance matrix. We will consider two basic approaches, one based on a family of estimators of the asymptotic covariance given in Equation (23.29), and a second, due to Windmeijer (2000, 2005), which employs a bias-corrected estimator which take into account the variation of the initial parameter estimates.
Using Equation (23.29) and inserting estimators and sample moments, we obtain an estimator for the asymptotic covariance matrix of :
(23.37)
where
(23.38)
Notice that the estimator depends on both the final coefficient estimates and the used to form the estimation weighting matrix, as well as an additional estimate of the long-run covariance matrix . For weight update methods which iterate the weights until the coefficients converge the two sets of coefficients will be identical.
EViews offers a number of different covariance specifications of this form, Estimation default, Estimation updated, Two-stage Least Squares, White, HAC (Newey-West), Windmeijer, Cluster-robust, and User defined, each corresponding to a different estimator for .
Of these, Estimation default and Estimation update are the most commonly employed coefficient covariance methods. Both methods compute using the estimation weighting matrix specification (i.e. if White was chosen as the estimation weighting matrix, then White will also be used for estimating ).
• Estimation default uses the previously computed estimate of the long-run covariance matrix to form . The asymptotic covariance matrix simplifies considerably in this case so that .
• Estimation updated performs one more step 3 in the iterative estimation procedure, computing an estimate of the long-run covariance using the final coefficient estimates to obtain . Since this method relies on the iterative estimation procedure, it is not available for equations estimated by CUE.
In cases, where the weighting matrices are iterated to convergence, these two approaches will yield identical results.
The remaining specifications compute estimates of at the final parameters using the indicated long-run covariance method. You may use these methods to estimate your equation using one set of assumptions for the weighting matrix , while you compute the coefficient covariance using a different set of assumptions for .
The primary application for this mixed weighting approach is in computing robust standard errors. Suppose, for example, that you want to estimate your equation using TSLS weights, but with robust standard errors. Selecting Two-stage least squares for the estimation weighting matrix and White for the covariance calculation method will instruct EViews to compute TSLS estimates with White coefficient covariances and standard errors. Similarly, estimating with Two-stage least squares estimation weights and HAC - Newey-West covariance weights produces TSLS estimates with HAC coefficient covariances and standard errors.
Note that it is possible to choose combinations of estimation and covariance weights that, while reasonable, are not typically employed. You may, for example, elect to use White estimation weights with HAC covariance weights, or perhaps HAC estimation weights using one set of HAC options and HAC covariance weights with a different set of options. It is also possible, though not recommended, to construct odder pairings such as HAC estimation weights with TSLS covariance weights.
Various Monte Carlo studies (e.g. Arellano and Bond 1991) have shown that the above covariance estimators can produce standard errors that are downward biased in small samples. Windmeijer (2000, 2005) observes that part of this downward bias is due to extra variation caused by the initial weight matrix estimation being itself based on consistent estimates of the equation parameters.
Following this insight it is possible to calculate bias-corrected standard error estimates which take into account the variation of the initial parameter estimates. Windmeijer provides two forms of bias corrected standard errors; one for GMM models estimated in a one-step (one optimal GMM weighting matrix) procedure, and one for GMM models estimated using an iterate-to-convergence procedure.
The Windmeijer corrected variance-covariance matrix of the one-step estimator is given by:
(23.39)
where:
, the estimation default covariance estimator
, the updated weighting matrix (at final parameter estimates)
, the estimation updated covariance estimator where
, the estimation weighting matrix (at initial parameter estimates)
, the initial weighting matrix
is a matrix whose th column is given by :
The Windmeijer iterate-to-convergence variance-covariance matrix is given by:
(23.40)
where:
, the GMM weighting matrix at converged parameter estimates
Weighted GMM
Weights may also be used in GMM estimation. The objective function for weighted GMM is,
(23.41)
where is the long-run covariance of where we now use to indicate the diagonal matrix with observation weights .
The default reported standard errors are based on the covariance matrix estimate given by:
(23.42)
where .
To estimate an equation by GMM, either create a new equation object by selecting Object/New Object.../Equation, or press the Estimate button in the toolbar of an existing equation. From the Equation Specification dialog choose Estimation Method: GMM. The estimation specification dialog will change as depicted below.
To obtain GMM estimates in EViews, you need to write the moment condition as an orthogonality condition between an expression including the parameters and a set of instrumental variables. There are two ways you can write the orthogonality condition: with and without a dependent variable.
If you specify the equation either by listing variable names or by an expression with an equal sign, EViews will interpret the moment condition as an orthogonality condition between the instruments and the residuals defined by the equation. If you specify the equation by an expression without an equal sign, EViews will orthogonalize that expression to the set of instruments.
You must also list the names of the instruments in the Instrument list edit box. For the GMM estimator to be identified, there must be at least as many instrumental variables as there are parameters to estimate. EViews will, by default, add a constant to the instrument list. If you do not wish a constant to be added to the instrument list, the Include a constant check box should be unchecked.
For example, if you type,
Equation spec: y c x
Instrument list: c z w
the orthogonality conditions are given by:
(23.43)
If you enter the specification,
Equation spec: c(1)*log(y)+x^c(2)
Instrument list: c z z(-1)
the orthogonality conditions are:
(23.44)
Beneath the Instrument list box there are two dropdown menus that let you set the Estimation weighting matrix and the Weight updating.
The Estimation weight matrix dropdown specifies the type of GMM weighting matrix that will be used during estimation. You can choose from Two-stage least squares, White, HAC (Newey-West), and User-specified. If you select HAC (Newey West) then a button appears that lets you set the weighting matrix computation options. If you select Cluster-robust, you will be prompted for a cluster series. If you select User-specified you must enter the name of a symmetric matrix in the workfile containing an estimate of the weighting matrix (long-run covariance) scaled by the number of observations ). Note that the matrix must have as many columns as the number of instruments specified.
The matrix can be retrieved from any equation estimated by GMM using the @instwgt data member (see “Equation Data Members”). @instwgt returns which is an implicit estimator of the long-run covariance scaled by the number of observations.
For example, for GMM equations estimated using the Two-stage least squares weighting matrix, will contain (where the estimator for the variance will use or the no d.f. corrected equivalent, depending on your options for coefficient covariance calculation). Equations estimated with a White weighting matrix will return .
Storing the user weighting matrix from one equation, and using it during the estimation of a second equation may prove useful when computing diagnostics that involve comparing J-statistics between two different equations.
The Weight updating dropdown menu lets you set the estimation algorithm type. For linear equations, you can choose between N-Step Iterative, Iterate to Convergence, and Continuously Updating. For non-linear equations, the choice is between Sequential N-Step Iterative, Sequential Iterate to Convergence, Simultaneous Iterate to Convergence, 1-Step Weight Plus 1 Iteration, and Continuously Updating.
To illustrate estimation of GMM models in EViews, we estimate the same Klein model introduced in “Estimating LIML and K-Class in EViews”, as again replicated by Greene 2008 (p. 385). We again estimate the Consumption equation, where consumption (CONS) is regressed on a constant, private profits (Y), lagged private profits (Y(-1)), and wages (W) using data in “Klein.WF1”. The instruments are a constant, lagged corporate profits (P(-1)), lagged capital stock (K(-1)), lagged GNP (X(-1)), a time trend (TM), Government wages (WG), Government spending (G) and taxes (T). Greene uses the White weighting matrix, and an N-Step Iterative updating procedure, with N set to 2. The results of this estimation are shown below:
The EViews output header shows a summary of the estimation type and settings, along with the instrument specification. Note that in this case the header shows that the equation was linear, with a 2 step iterative weighting update performed. It also shows that the weighing matrix type was White, and this weighting matrix was used for the covariance matrix, with no degree of freedom adjustment.
Following the header the standard coefficient estimates, standard errors, t-statistics and associated p-values are shown. Below that information are displayed the summary statistics. Apart from the standard statistics shown in an equation, the instrument rank (the number of linearly independent instruments used in estimation) is also shown (8 in this case), and the J-statistic and associated p-value is also shown.
As a second example, we also estimate the equation for Investment. Investment (I) is regressed on a constant, private profits (Y), lagged private profits (Y(-1)) and lagged capital stock (K-1)). The instruments are again a constant, lagged corporate profits (P(-1)), lagged capital stock (K(-1)), lagged GNP (X(-1)), a time trend (TM), Government wages (WG), Government spending (G) and taxes (T).
Unlike Greene, we will use a HAC weighting matrix, with pre-whitening (fixed at 1 lag), a Tukey-Hanning kernel with Andrews Automatic Bandwidth selection. We will also use the Continuously Updating weighting updating procedure. The output from this equation is show below:
Note that the header information for this equation shows slightly different information from the previous estimation. The inclusion of the HAC weighting matrix yields information on the prewhitening choice (lags = 1), and on the kernel specification, including the bandwidth that was chosen by the Andrews procedure (2.1803). Since the CUE procedure is used, the number of optimization iterations that took place is reported (39).
