Object Reference : Object View and Procedure Reference : Model
compare
Produce a table showing the differences between scenarios for the specified series.
model_name.compare(options) model_vars
The compare view allows you to quickly compare the results from different scenarios (or the actual values) following a model solve. By default the output table will show any of the series specified in model_vars whose difference between the current active and comparison scenarios exceeds a specified tolerance. You may optionally use the “patt=” option to specify a separate set of comparison series from those in the current comparison scenario.
The list of model_vars may include the following special keywords:
@all
All model variables.
@endog
All endogenous model variables.
@exog
All exogenous model variables.
@addfactor
All add factor variables in the model.
@overides
All currently overridden exogenous variables
@excludes
All currently overridden endogenous variables
tol=num
Set the tolerance level for comparing the series. Any differences below the tolerance will not be reported. Default value is 0.001.
patt=”pattern”
Set the comparison set of series. Without this option, EViews will build the comparison set based upon the current comparison scenario. This option allows you to select a different set of series using pattern matching. pattern should contain an * to represent the variable names given in model_vars.
mod1.scenario(a="_0") "scenario0"
mod1.scenario(c, a="_1") "scenario1"
mod1.solve(a=t)
mod1.compare gdp unemp infl
The first two lines of this example set the current active scenario “Scenario0”, and set the comparison scenario to “Scenario1”, with a name alias of “_1”. The model is then solved for both scenarios. The compare command is used to produce a table detailing the differences between the two scenarios for the three variables GDP, UNEMP and INFL. Any differences between the solved series GDP_0 and GDP_1, UNEMP_0 and UNEMP_1 or INFL_0 and INFL_1 greater than 0.001 will be shown in the table.
mod1.compare(tol=0.00001) gdp unemp infl
produces the same table, but uses a lower tolerance rate (of 0.00001).
mod1.compare @endog
produces a table comparing all endogenous variables in the model, not just GDP, UNEMP and INFL.
mod1.compare(patt="*_2") gdp unemp infl
produces a table that compares GDP_0 with GDP_2, UNEMP_0 with UNEMP_2 and INFL_0 with INFL_2, even though the current comparison scenario is still “Scenario1”.
See “Models” for a discussion of specifying and solving models in EViews. See also, the discussion in “Specifying Scenarios”.
See Model::scenario and Model::adjust.
