Object Reference : Object View and Procedure Reference : Rowvector
edftest
Computes goodness-of-fit tests based on the empirical distribution function.
Compute Kolmogorov-Smirnov, Lilliefors, Cramer-von Mises, Anderson-Darling, and Watson empirical distribution function tests.
rowvector_name.edftest(options)
General Options
dist=arg (default=”nomal”)
Distribution to test: “normal” (Normal distribution), “chisq” (Chi-square distribution), “exp” (Exponential distribution), “xmax” (Extreme Value - Type I maximum), “xmin” (Extreme Value Type I minimum), “gamma” (Gamma), “logit” (Logistic), “pareto” (Pareto), “uniform” (Uniform).
p1=number
Specify the value of the first parameter of the distribution (as it appears in the dialog). If this option is not specified, the first parameter will be estimated.
p2=number
Specify the value of the second parameter of the distribution (as it appears in the dialog). If this option is not specified, the second parameter will be estimated.
p3=number
Specify the value of the third parameter of the distribution (as it appears in the dialog). If this option is not specified, the third parameter will be estimated.
prompt
p
Print test results.
Estimation Options
The following options apply if iterative estimation of parameters is required:
b
Use Berndt-Hall-Hall-Hausman (BHHH) algorithm. The default is Marquardt.
m=integer
Maximum number of iterations.
c=number
Set convergence criterion. The criterion is based upon the maximum of the percentage changes in the scaled coefficients.
showopts / ‑showopts
[Do / do not] display the starting coefficient values and estimation options in the estimation output.
s
Take starting values from the C coefficient vector. By default, EViews uses distribution specific starting values that typically are based on the method of the moments.
The command
rvec1.edftest
uses the default settings to test whether the elements of the rowvector RVEC1 come from a normal distribution. Both the location and scale parameters are estimated from the data in RVEC1.
rvec1.edftest(type=chisq)
tests whether the data in RVEC1 follow a distribution with degrees-of-freedom estimated from the data.
freeze(tab1) rvec1.edftest(type=chisq, p1=5)
tests whether the data in RVEC1 comes from a distribution with 5 degrees-of-freedom. The output is stored in the table object TAB1.
See “Empirical Distribution Tests” for a description of the goodness-of-fit tests.
See also qqplot.
