Object Reference : Object View and Procedure Reference : Series
ipolate
Fill in missing values, or NAs, within a series by interpolating from values that are not missing.
series_name.ipolate(options) series_name
type = key
Specify the interpolation method. key is either “lin” (linear, default), “log” (log-linear), “cs” (Cardinal spline), “cr” (Catmull-Rom spline), “cb” (Cubic spline), “lcs” (log-cardinal spline), “lcr” (log-Catmull-Rom spline), or “lcb” (log-cubic spline).
tension = number
Sets the tension parameter for the Cardinal spline method of interpolation. number should be a number between 0 and 1.
f = arg (default = “actual”)
Out-of-sample fill behavior: “actual” (fill observations
outside the interpolated sample with values from the source series). “na” (fill observations outside the sample with missing values”
prompt
The following lines interpolate the missing values of series X1 using linear interpolation, and store the new interpolated series with a name X_INTER:
x1.ipolate x_inter
This line performs the same interpolation, but this time using the Cardinal spline, with a tension value of 0.8:
x1.ipolate(type=cs, tension=0.8) x_inter
See “Interpolate” for discussion.
