User’s Guide : Multiple Equation Analysis : Impulse Response Analysis : Impulse Response Confidence Intervals
Analytic Asymptotic (Delta Method)
Traditional VAR Analytic
Local Projection Analytic
Sequential Estimation
Joint Estimation
Monte Carlo (MC Integration)
Bootstrapping
Bootstrap Theory
Types of Bootstrap
Residual Based Bootstrap
Block of Blocks Bootstrap
Double Bootstrap
Fast Double Bootstrap
Traditional VAR Bootstrap
Confidence Interval Methods
Standard Percentile Confidence Interval
Hall's Percentile Confidence Interval
Hall's Studentized Confidence Interval
Kilian's Unbiased Confidence Interval
Local Projection Bootstrap
Additional Confidence Interval Methods
Jordà Confidence Interval
Randomized Impulses
Traditional VEC Bootstrap
In addition to estimating the impulse response path, we may wish to obtain confidence intervals for those estimates. There are a variety of approaches to obtaining these estimates.
Joint Estimation
An extensive theoretical overview on analytic confidence intervals may be found in Chapter 3 of Lütkepohl (2005).
Briefly, the theoretical results are based on a first-order expansion (delta method) of the asymptotic normal distribution of the impulse response estimate.
Without loss of generality (i.e., remaining agnostic about the method of estimation and structural identification), consider an arbitrary full impulse response path matrix:
and let and denote respectively the vectorized forms of and its estimate. Then, as usual, we have the following asymptotic result:
(46.20)
Then, as usual, we can construct confidence interval bands for the impulse response path as:
(46.21)
where denotes the -vector of diagonal elements of the estimated covariance matrix , and denotes the -quantile of the standard Gaussian distribution.
Note that these bands capture the unconditional uncertainty of the impulse response coefficients at each horizon step . While these results are both useful and valid, this approach to confidence interval computation ignores the collinearity among impulse response coefficients, and ignores the temporal ordering of the impulse response path. The latter is a particularly important omission as a given value of the impulse response path affects the future trajectory of the path, but not conversely.
Lütkepohl describes analytic estimation of the covariance matrix for results obtained from traditional VAR estimation and provides the necessary equations for its computation.
Let and . Then we have the following asymptotic results:
(46.22)
where
(46.23)
and .
The covariance of the impulse responses, , described in Equation (46.23) is the sum of two components:
• reflects the uncertainty associated with the slope parameter estimates
• captures the uncertainty associated with the estimate of
The nominal % confidence interval for a specific impulse response coefficient at horizon step satisfies:
(46.24)
where is the -th element of .
Joint Estimation
The limiting distribution theory for the sequential local projection impulse response estimator can be derived analogously. Consider again the asymptotic result:
(46.25)
where,
(46.26)
where is the covariance of the .
Then, as in Equation (46.24):
(46.27)
Jordà (2005) warns that the innovation process of the local-projection regression has a moving average component of order . Although the presence of the moving average doesn’t affect estimator consistency, Jordà (2005) recommends the use of a Newey-West estimator for at each horizon step to improve the accuracy of the confidence interval estimate.
Joint Estimation
Since the residuals from a local-projection regression exhibit a moving average component of order , for sequential estimation, Jordà (2005) recommends use of a Newey-West estimator of the residual covariance matrix at each horizon step .
Alternately, Jordà (2009), shows it is possible to address this issue parametrically, and derives the correct covariance matrix of the full path of the impulse response coefficients:
(46.28)
where we replace the estimated in Equation (46.26) with , and is a transformation matrix that depends on the lag coefficients of the LP (Jordà 2009, p. 642).
Recall that the sequential confidence intervals in Equation (46.24) and Equation (46.27) ignore collinearity among impulse response coefficients, and the temporal ordering of the impulse response path. To address these issues, Jordà (2009) proposes two simultaneous confidence band computations, the Scheffé band and the conditional error band.
The Scheffé's band is given by:
(46.29)
which we obtain using the LDL decomposition of
(46.30)
where is a lower triangular matrix with 1’s along the main diagonal; is a diagonal matrix, and is the critical value of .
An alternative joint confidence band is the conditional error band:
(46.31)
Scheffé bands provide a rectangular approximation to the elliptical simultaneous confidence region of impulse response coefficients. Alternately, conditional error bands separate the variation of each impulse response coefficient from the variation resulting from impulse response serial correlation. Thus, conditional error bands are better at identifying the significance of individual impulse response coefficients analogous to the way a Wald test on coefficient joint significance works.
Note that, even with joint estimation, we can compute the classical confidence bands by ignoring serial correlation and collinearity by deriving the band using only the diagonal elements of .
An alternative method of computing impulse response confidence intervals is provided by Sims and Zha (1999). This Bayesian approach simulates the posterior distribution of the impulse response conditional on the p pre-sample observations. Assuming Gaussian innovations, the distribution of interest is normal-inverse Wishart. As the theory has only been developed given traditional VAR estimation, we only employ this method in that context.
From “Impulse Response Confidence Intervals” we see that the impulse response path is a nonlinear function of the vectorized VAR coefficients , and the vectorized residual covariance matrix , which we may denote as
The method of MC integration is based on drawing from the posterior distribution, , where:
(46.32)
The error bands are obtained as the and percentiles of the simulated posterior distribution of the impulse response coefficients. Extending the result to structural shocks is straightforward and only requires scaling by an appropriate .
Bootstrapping
Bootstrap Theory
Types of Bootstrap
Double Bootstrap
Bootstrap Theory
Types of Bootstrap
Double Bootstrap
Suppose there exists a data generating process (DGP) we're interested in estimating. Without loss of generality, we can assume such a DGP is parametric with a particular model specification , an associated core dataset , some parameter space , and an auxiliary data/parameter space to complete the specification. We can succinctly describe such a DGP as a tuple
(46.33)
To formalize matters, assume a simple autoregressive DGP of the form
(46.34)
Then, , , and .
Finally, let the object of statistical interest (e.g., estimator, test statistic, etc.) be some functional of the data and parameters:
(46.35)
Then, the general principle governing bootstrap methods is that distribution of can be approximated by generating a large number, say , of different outcome paths ( with ) for , where the superscript indicates that the object is derived from simulation. In particular, the outcomes are obtained by simulating from (via repeated applications of ) to generate independent outcomes of , and for each such draw, estimate and compute the corresponding in the same way was derived from the original data. is then estimated as the empirical distribution of .
Note that the final bootstrap estimator of , typically denoted as , is derived as the average of the individual bootstrap estimates . In other words:
(46.36)
Types of Bootstrap
Four our purposes it is useful to distinguish between two types of bootstrap simulation: residual based boostrap and blocks of blocks bootstrap.
In traditional regression settings, the bootstrap procedure often used to obtain is the residual based bootstrap. Assuming a simple autoregressive DGP of the form above, the algorithm is summarized below:
1. Estimate to derive estimates and the residual process .
2. For each :
a. Randomly draw with replacement from to obtain bootstrap innovations .
b. Simulate bootstrap data via (i.e., recursively).
c. Generate the bootstrap DGP:
(46.37)
d. Estimate to derive estimates and .
e. Obtain a bootstrap estimate of the object of interest as:
(46.38)
The block of blocks bootstrap is a non-parametric method designed to accommodate weakly dependent stationary observations. While there are several implementations of this methodology, each addressing important practical aspects, here we only outline the basic idea. In particular, data is bootstrapped by selecting blocks of length randomly with replacement from . Again, assuming a simple autoregressive DGP shown earlier, the algorithm is described below:
1. Define overlapping blocks of data of length . In other words, form a matrix .
2. For each :
a. Simulate bootstrap data via where . In other words, draw with replacement from the columns of .
b. Generate the bootstrap DGP:
c. Estimate to derive estimates and .
d. Obtain a bootstrap estimate of the object of interest as:
Double Bootstrap
It is sometimes necessary to obtain bootstrapped versions of bootstrap statistics. For instance, the object of interest may be the distribution of . This is typically needed in deriving the variance of a bootstrap statistic. In this case, for each , the distribution is approximated by generating a large number, say , of different outcome paths ( with ) for , where the superscript indicates that the object is derived from a second stage bootstrap simulation. In particular, the outcomes are obtained by simulating from each first stage bootstrap DGP in exactly the same way that was simulated from the original DGP. is estimated as the empirical distribution of
(46.39)
Performing a full double bootstrap algorithm is extremely computationally demanding. A single bootstrap algorithm typically requires the computation of test statistics -- a single statistic performed on the original data and an additional statistics obtained in the bootstrap loop. On the other hand, a full double bootstrap requires statistics, with the additional statistics computed in the inner loop of the double bootstrap algorithm. For instance, setting and , the double bootstrap will require the computation of no less than 499,501 test statistics.
Several attempts have been proposed to reduce this computational burden, among the most popular of which is the fast double bootstrap (FDB) algorithm of Davidson and MacKinnon (2002) and general iterated variants proposed in Davidson and Trokic (2020). The principle governing the success of these algorithms relies on setting . For instance, the FDB has proved particularly useful in approximating full double bootstrap algorithms with roughly less than the twice the computational burden of the traditional bootstrap: to be precise.
To derive bootstrap confidence intervals for traditional VAR impulse response paths, let , , denote, respectively, some general impulse response coefficient, estimated using the original data and the DGP in Equation (46.1), and the associated bootstrap estimator so that .
The choice of bootstrap algorithm to derive is not particularly important. Traditionally, a procedure like the residual bootstrap is widely used for traditional VAR impulse response analysis. While modern approaches do suggest the viability of the block of blocks bootstraping, To follow the original literature, however, EViews offers only the residual bootstrap methods described above ( “Residual Based Bootstrap”) for the case of impulse responses derived via traditional VARs.
Let denote a given significance level so that the confidence interval of interest has coverage . Then, the following bootstrap confidence intervals have been considered in the impulse response literature. See Lütkepohl (2005) for further details.
The most common bootstrap algorithm for impulse response CIs is based on the percentile confidence interval described in Efron and Tibshirani (1993). The bootstrap CI is derived as:
(46.40)
where and are respectively the and quantiles of the empirical distribution of .
An alternative to the standard percentile CI is the Hall (1992) confidence interval. The idea behind this contribution is that the distribution of is asymptotically approximated by the distribution of . Accordingly, the bootstrap CI is derived as:
(46.41)
where and are respectively the and quantiles of the empirical distribution of . See Hall (1986) for details.
Another possibility is to asymptotically approximate the distribution of the studentized statistic , formalized as:
(46.42)
with the distribution of the bootstrap studentized statistic:
(46.43)
In this case, the bootstrap CI is derived as:
(46.44)
where and are respectively the and quantiles of the empirical distribution of where:
(46.45)
Here, can be estimated from the individual bootstrap estimates . In particular:
(46.46)
where .
Naturally, extending the argument above, can be estimated from an additional double bootstrap estimates . In this regard, the re-sampling mechanism is obtained by augmenting the residual based bootstrap algorithm to the double bootstrap approach ( “Double Bootstrap”). In particular:
(46.47)
where .
Alternately, we may employ the less computationally demanding fast double bootstrap approximation. Davidson and Trokic (2020) offer an algorithm to derive confidence intervals based on the FDB. The idea relies on the inverse relationship between -values and confidence intervals. In particular, any -value can be converted into a confidence bound through inversion. Thus, the FDB CI algorithm first derives the FDB -values for a studentized test statistic that rejects in the lower and upper tails as follows:
(46.48)
where is the usual indicator function and is the bootstrap -value derived as follows:
(46.49)
and is the empirical -quantile of the second stage bootstrap statistics . Note here that the latter are obtained by setting , thereby achieving a significant computational speedup.
Next, the algorithm inverts to obtain the lower and upper confidence bounds by solving the equation:
(46.50)
The solution to this inversion, in case of lower and upper bounds, is as follows:
(46.51)
where is the empirical -quantile of the first stage bootstrap statistics .
Care should be taken however, as Chang and Hall (2015) show that the FDB does not improve asymptotically on the single bootstrap for the construction of confidence intervals.
The Kilian (1998) confidence intervals are specifically designed for VAR impulse response estimates. In particular, this approach explicitly corrects for the bias and skewness in the impulse response estimator that arises due to insufficient observations. We skip over most of the details but an overview of the procedure proceeds as follows:
1. Estimate a VAR to obtain original coefficient estimates.
2. Run a residual bootstrap to obtain bootstrap coefficient estimates which are used to compute a bias correction adjustment to the original estimates.
3. Use the bias corrected coefficients as the basis of a residual double bootstrap to bias correct each of the bootstrap coefficients.
4. Construct the impulse responses using the bias corrected bootstrap coefficients.
5. Derive the and empirical quantiles of the bias corrected bootstrap impulse responses.
Note that the nested bootstrap computations required for this method can be costly. A fast bootstrap approximation may be obtained by computing the bias adjustments only once per loop and using it across replications.
Randomized Impulses
One can also rely on bootstrap methods to derive confidence intervals for impulse responses derived via local projections. All that is really necessary is a bootstrap version of the data, namely , for . Once generated, we can apply local projection methods outlined in “Local Projection” in order to estimate accordingly.
We note here that the literature on bootstrap methods for impulse responses via local projections is not as developed as its traditional VAR counterpart.
While bootstrap methods outlined for traditional VARs are in principle valid for local projection, few papers formally consider the subject of bootstrapping impulse responses computed via local projections. Prominent amongst those that do, Kilian and Kim (2011) argue for using the block of blocks bootstrap to simulate .
In additional to the confidence interval methods describe above in “Confidence Interval Methods”, we may employ two additional methods specifically designed for use in local projection settings.
The Jordà (2009) confidence interval is specifically designed for impulse response estimates via local projections. What makes this method unique is that instead of deriving quantiles of impulse response paths directly, it derives quantiles via an auxiliary Wald statistic. We provide an overview of the methodology below:
1. Derive impulse response coefficients via local projections using original data.
2. Derive the Wald statistics below where is the variance (covariance) of the impulse response coefficient (path):
(46.52)
3. Derive the and empirical quantiles of . Let and respectively denote the indices associated with these two quantiles.
4. The desired confidence interval is then
(46.53)
Randomized Impulses
Kilian and Kim (2011) offer LP simulation experiments which suggest that treating the impulse matrix as random improves coverage accuracy of intervals compared with those based on initial point estimates for all bootstrap replications.
The principles governing the computation of bootstrap CIs for VAR impulse responses remain valid for VEC impulse responses as well. Since every VAR() has an equivalent representation as a VEC() process, one can simply convert bootstrap VAR estimates into their VEC equivalents, and proceed to derive the VEC impulse responses using the latter coefficients. Alternatively, one can start from a VEC representation, obtain bootstrap coefficient estimates, and then integrate the VEC model to its VAR equivalent. The converted bootstrap coefficient estimates can then be used to derive bootstrap CIs for the corresponding VAR.
