Variable Selection Estimation in EViews
To perform a variable selection procedure (VARSEL) in EViews select or press from the toolbar of an existing equation. From the dialog choose. EViews will display the following dialog:
The page allows you to provide the basic VARSEL regression specification. In the upper edit field you should first specify the dependent variable followed by the always included variables you wish to use in the final regression. Note that the VARSEL equation must be specified by list.
You should enter a list of variables to be used as the set of potentially included variables in the second edit field.
The dropdown box can be used to specify the type of selection procedure will be used to determine the final model. By default, EViews will estimate the variable selection using the method. To change the basic method, change the method dropdown menu; the dropdown allows you to choose between: , , , , and selection.
Next, you may use the Options tab to more finely tune the selection method. The options available will depend on the selection method chosen, and are described below.
Estimation Options
When you select one of the variable selection methods, the tab of the dialog will change to display the relevant settings.
Uni-directional and Stepwise Options
For the and methods you may specify the direction of the method using the and radio buttons and to provide a using either a p-value or t-statistic tolerance for adding or removing variables.
You may also choose to stop the procedures once they have added or removed a specified number of regressors by selecting the option and providing a number of the corresponding edit field.
The portion of the dialog is the same as that used in other estimators such as least squares. For more information, please see
“Weighted Least Squares”.
Swapwise Options
The Swapwise variable selection method lets you choose whether you wish to use Max R-squared Increment or Min R-squared Increment, and to enter the number of additional variables to be selected.
By default, the number of additional variables is set to one so that if you do not enter a value, EViews will select the single variable that will lead to the largest increase in R-squared.
Combinatorial Options
The combinatorial options page simply prompts you to provide the number of additional variables.
Auto-Search / GETS Options
When is chosen as the on the tab, the tab will change to display options specific to the Auto-Search/GETS algorithm:
The options are divided into several sections.
• The Model selection section offers options for the selection criteria used during the variable selection process. The Criteria dropdown specifies the information criteria used to select the final model from the candidates remaining in step 4) of the selection algorithm. The Include GUM and Include empty model checkboxes specify whether to include either the general model (i.e. the model with all possible search variables) or the empty model (the model with zero search variables) as candidates.
The Blocks edit field allows you to overwrite the EViews’ choice for the number of blocks into which to split the search variables if the number of search variables is greater than the number of observations.
• The
Diagnostics section identifies the options for the diagnostic tests used in the diagnostic tests steps 1) and 3) of the algorithm (
“Auto-Search / GETS”). The
Terminal condition p-value is used to set the
p-value against which the significance of the remaining variable is tested when determining whether to stop the selection process along a path in step 3).
The AR LM test, ARCH LM test, Normality test and PET test checkboxes are corresponding p-value edit fields are used to determine whether those tests are used when determining the validity of both the GUM and each selection model, and their associated p-value. For both the AR and ARCH LM tests, the number of lags used in the test may also be specified.
Lasso Options
For Lasso selection, the options dialog allows you specify the data transformation options for the regressors and, potentially, the properties of the lambda path, optimization settings, and details of the cross-validation:
(All of the options available for elastic net are also available for Lasso selection with the exception of the @VW tag.)
There are several sections in the dialog.
Regularization specification
The section prompts you to specify the regressor transformation and settings for lambda.
• For the former, the combo may be used to choose between (the default), by sample and population, and normalizations, and transformation.
For multiple supplied or default generated values of lambda in the section, the available options will expand to show additional lambda options:
• In the text box, you may supply the ratio of the minimum to the maximum value of lambda desired; the default is 0.0001.
• In the text box, you may supply the number of values of lambda on the path; the default is 100.
Estimation algorithm
The familiar section controls the specification of starting values and iterative estimation controls.
Penalty
If the Lasso selection method is chosen, then elastic net estimation is applied with
and variable weights equal to zero for the always included variables.
You should specify information about the Lasso lambda in the edit field.
You are free to fill in the lambda field with a single value, multiple values separated by spaces, or a series object from the workfile. If multiple values of lambda are entered, either directly as a list or through a series object, cross-validation will be performed to determine the value giving the model with the lowest measurement error.
You may also leave the lambda field blank. If you choose to do this EViews will generate its own list of values based on the data.
Cross-validation options
For multiple supplied or default generated values of lambda in the section, the available options will expand to include the . Certain options within this section can be chosen depending on the particular method of cross-validation chosen ( for , for example).
The available include:
• : After the dataset is divided into training and test sets, the ordering is shuffled. The and fields control the details of the shuffling. You may the leave the field blank, in which case EViews will use the clock to obtain a seed at the time of estimation, or you may provide an integer from 0 to 2,147,483,647. The button may be used to clear the seed used by a previously estimated equation. By changing the value of the field from the default of 1 you may create multiple datasets with different, shuffled ordering of training and test sets.
• : The dataset is divided into K evenly spaced “folds” and the ordering is shuffled (the details of the shuffling are determined by the and fields). One fold is held out as the test set while the remaining K-1 folds are combined into the training set. This process is then repeated, with each fold being held out in turn as the test set. After model estimation the statistics are averaged over all K folds.
• : This is the same as K-Fold, but with the number of folds equal to the number of observations.
• : This is similar to K-Fold, with the exception that a test set of size P is held out, with the remaining data forming the training set. This process is repeated over all remaining combinations.
• : After a window size is chosen for the dataset, the window is divided into training and test sets (the default test set size is 1, and you may also choose the test set size as a fraction), with the test set in each window always coming after the training set. The window “rolls” through the dataset until it reaches the end of the dataset. You may also choose how far ahead of the training set you want the test set to be (the horizon), as well as an initial period in the dataset to hold out of the cross-validation (the initial period).
• : The dataset is divided into training and test sets (the default test set size is 1, and only integer test set sizes are allowed), with the test set in each window always coming after the training set. With each iteration the training set size expands by one while the test set stays the same size. You may choose how far ahead of the training set you want the test set to be (the horizon), as well as an initial period in the dataset to hold out of the cross-validation (the initial period).
Weights
